WORKS P1 Flash Dyno sheet
Old Jul 8, 2008 | 08:01 PM
  #61
Deepside's Avatar
But don't forget that a piggy can probably be removed without trace for the warranty, while a flash would take a week and another 399.
But well, if the dyno show better number with a flash... it won't be hard to decide
Old Jul 8, 2008 | 08:23 PM
  #62
mezzedupdream's Avatar
Actually I believe if you go in for warranty work, I think if mitsu flashes it back, you can get it flashed for free by works. Correct me if i'm wrong, but i'm pretty positive I read it somewhere.
Old Jul 9, 2008 | 07:49 AM
  #63
Evolve247's Avatar
I purposely left that part out. Babygotback only wanted to know what he should expect from each device. I wasn't trying to give him a sales-pitch or anything
Old Jul 9, 2008 | 06:12 PM
  #64
Bawb3's Avatar
Originally Posted by Evolve247
My PZEV header did NOT give me 13 hp. Sure i felt an amazing difference. But it wasn't anything that high. The stock piece sure does suck. That's for sure.
Yeah, I'm sure it helped, but don't forget that the header isn't the only restriction/difference between FED and PZEV. I've heard there are different cams in it as well, and I think the Ecu is mapped differently(Don't hold me to that, although it would make sense if they're trying to set it up to burn cleaner). Just replacing the header isn't going to completely close the gap between the two.
If my understanding of this situation is correct, Crc'22 got the works reflash done? His total hp/tq ended up equal to the dyno results posted by WORKS at the beginning of this thread. He had some mods done that should've put his dyno results above WORKS' stock dyno results. If I'm wrong, then just disregard my banter, lol.
Chances are - cRc's exhaust + fliter + reflash put it up even to a stock FED lancer + reflash. Plus there are always going to be variations in different dyno tests.
Old Jul 13, 2008 | 09:29 AM
  #65
the_cosworth's Avatar
Actually you are incorrect. You cannot remove the piggy without major traces. When mitsu sees that you have cut into the wiring harness your entire warranty will be void.
The ECU flash can be taken to Mitsu where they cant see any difference once it is flashed unless they go into the fuel map tables and compare them to stock (which they wouldn't). Plus works will reflash for free if Mitsu writes over it
Old Jul 13, 2008 | 09:51 AM
  #66
samj601's Avatar
how come you guys havent made anything for the 04-06 ralliarts?
Old Jul 13, 2008 | 01:28 PM
  #67
Deepside's Avatar
Well just put some wire protector wire or something over the wires and say's you like when it's tidy lol.
But it's good to know they will reflash it free.
Old Jul 14, 2008 | 05:39 PM
  #68
you have to cut the MAF (dont quote me on that) wire so it can alter it.
I know what your saying but unless you can do a REALLY clean job they are going to see the spices
Old Aug 9, 2008 | 12:41 AM
  #69
jebodiah1699's Avatar
is this flash available for 09' fed gts cvts??
Old Aug 31, 2008 | 01:30 AM
  #70
Gts_BlackJoker's Avatar
BUMP again, hopefully some new info may come to light....WORKS?
Old Aug 31, 2008 | 02:22 AM
  #71
cRc`22's Avatar
what info are u looking for..?? i think im the only one that has the flash.. lmao
Old Aug 31, 2008 | 01:35 PM
  #72
elpoole's Avatar
I have the flash. Great inprovement. Purrs like a tiger.
Old Aug 31, 2008 | 04:16 PM
  #73
GTS_Rob's Avatar
thats two
Old Aug 31, 2008 | 09:37 PM
  #74
cRc`22's Avatar
Originally Posted by GTS_Rob
thats two
dont be hatin
Old Sep 1, 2008 | 01:13 AM
  #75
Care to elaborate cause i am really thinking about buy it now that i have paid off all tickets
