Scantech
Old Jan 13, 2009 | 01:40 PM
ThunderOZ's Avatar
Scantech
So I've read that I can use Scantech to read/clear check engine lights. However, when I try to download it from aktivematrix, it doesn't finish downloading or won't load. If anyone has a working version of it can you send it too me? I could really use the help.
Also, if you are using something different, please post what it is and your feelings on it.
Thanks,
Merc
Old Jan 13, 2009 | 10:56 PM
senate6268's Avatar
I've been using ScanTech for almost 2 years now on and off and highly recommend it. I just hopped onto AktiveMatrix and was able to successfully re-download the file. When I've always run the program it won't connect until try #2. The first time will try to connect on all settings and fail. Retrying to connect establishes an immediate connection.
Old Jan 15, 2009 | 08:58 PM
ThunderOZ's Avatar
does it only work on xp? I have two laptops I can use for the car, one with vista x64 and the other with xp sp3...
Old Jan 15, 2009 | 09:08 PM
TouringBubble's Avatar
It hasn't been supported for a while, so it might not work with Vista.
Old Jan 16, 2009 | 12:04 AM
sykou's Avatar
i got it on my laptop but im running windows 2000. dont think it has support for anything higher does it?
Old Jan 16, 2009 | 10:04 AM
I run it on XP just fine. It sometimes won't connect to non-Mitsu cars though.
Old Jan 19, 2009 | 06:26 PM
ThunderOZ's Avatar
It's still not working for me...
SmurfZilla
May 30, 2015 07:33 AM
SmurfZilla
Jun 11, 2013 10:44 PM
oldevodude
Jul 21, 2010 03:37 PM
CLaNZeR
Dec 28, 2008 01:13 PM
steadly2004
Sep 28, 2008 04:28 PM
