Road Race Timing Module Testimonial
Old Mar 4, 2009 | 10:07 PM
  #31
firedawg81's Avatar
I know its tough to tell a whole lot of difference but if you look on each video my rpm gauge starts to move at about 2 seconds in. With the module I hit 60 mph right as it hits 12 seconds. Without it I hit 60 right around 13-14 second. I even used my stopwatch and found about a 1 second difference. Of course I know each run wasn't exactly the same but just some food for thought.
Old Mar 4, 2009 | 10:11 PM
  #32
I Am God's Avatar
r u all stock except for timing mod or what else u got?
Old Mar 4, 2009 | 10:15 PM
  #33
firedawg81's Avatar
right now just CAI.
Old Mar 5, 2009 | 05:25 AM
  #34
BABYGOTBACK's Avatar
Originally Posted by firedawg81
Ok so here are the two videos I took with and without the timing module. These were taken with my old timing module so the CEL is still on when the module is plugged in. Notice how the RPMS gain considerably faster after 4k RPM or so with the module. Also its not very flat around here so I tried to find the best place possible. Also keep in mind I drive a cvt. Enjoy =)
With Module
http://www.youtube.com/watch?v=QzBhyctTkrM
Without Module
http://www.youtube.com/watch?v=ZpXWQ8WrcbY
Sorry had to edit because embedding didnt work =)
I appreciate that you at least had the sack to do a video!! But from my calculations on your videos, I got your 0 to 60 times both being exactly 10 seconds. That is with a CAI, and the temps there in Idaho have to be freezing cold to help with air density as well! My old man lives in Couer de Alene! Thanks again for the video, not sure if there is any difference with the manual transmission, but from your video, I have decided against getting the timing module at this point until someone has better results!
Old Mar 5, 2009 | 05:36 AM
  #35
With Module
Without Module
I appreciate that you at least had the sack to do a video!! But from my calculations on your videos, I got your 0 to 60 times both being exactly 10 seconds. That is with a CAI, and the temps there in Idaho have to be freezing cold to help with air density as well! My old man lived in Couer de Alene! Thanks again for the video, not sure if there is any difference with the manual, but from your video, I have decided against getting the timing module at this point until someone has better results!
Old Mar 5, 2009 | 09:36 AM
  #36
100$ GUY's Avatar
Yeah, thanks firedawg for the videos!
Weird, but mine seems to rev faster than yours..... even stock. Maybe its just in my head Man, if only I had the VBOX....
Old Mar 5, 2009 | 09:54 AM
  #37
100$ GUY's Avatar
The older modules had different codes on them that set off the CEL code that I had.
So rock, be careful and dont send me an older module, dont want any CEL.
Old Mar 5, 2009 | 10:42 AM
  #38
guero.casal's Avatar
What I'm seeing here is that with the Timing Module you rev the car to 6K and it's still pushing instead of the 5.5K for the first video, at least in the video that's what happened
Old Mar 5, 2009 | 12:57 PM
  #39
firedawg81's Avatar
Yeah but if you notice at the top of 3rd I actually govern out for a little bit with the timing mod vid so I wasted some time. I definitely notice the difference. You have to keep in mind that there are hills around here, wind, and I'm trying to drive and film.
Old Mar 5, 2009 | 12:59 PM
  #40
Seems like the Timing module has the same "effect" as the Light weight pulley. It is not a real noticeable difference, but helps the motor get to higher RPM's quicker?! COrrect me if I am wrong.
Old Mar 5, 2009 | 01:47 PM
  #41
LuDa's Avatar
if you time them..both runs are about the exact same time..if anything the 2nd one being .2 secs faster.
Old Mar 5, 2009 | 02:33 PM
  #42
firedawg81's Avatar
Yeah you have to realize though that there are a lot of variables in these videos. You've seen the dyno sheets. I'm sure those are quite a bit more accurate than my videos. I thought about getting my ride dynoed but I don't see any reason to fork out 50$ right now to do that.
Old Mar 5, 2009 | 04:50 PM
  #43
WhiteGTS18's Avatar
Originally Posted by 100$ GUY
That video has got to be your next priority!
Whitegts said the same thing, but hasnt done it yet and its been over a month.
What was wrong with the older modules??
haha sorry guys its freezing over here and the roads have been crappy or ive been busy. ill do it soon i just need to install the software on my computer again for the dashhawk to get the 0-60 graph. never said video though
Old Mar 10, 2009 | 10:15 AM
  #44
100$ GUY's Avatar
Yeah do your homework, people are anxious! Just look at the other thread....
Old Mar 13, 2009 | 04:02 AM
  #45
ejlancer's Avatar
i like it, works great for me. Not as much performance as i thought it was going to produce but still a nice upgrade
