Evoscan Issues
Old Mar 10, 2009 | 07:46 PM
ThunderOZ's Avatar
Evoscan Issues
While I finally got EcuFlash to work without any problems on my laptop so I downloaded EvoScan to start tuning.
The problem is, I throw errors when I go to open the program. It is the latest version v2.5 and here is a picture of the message:
EDIT:So I just had to run the program as an administrator so issue fixed, new problem on post 3
Old Mar 10, 2009 | 09:09 PM
ThunderOZ's Avatar
Btw, the laptop it is running on is a 64bit version of Vista Home Premium.
Old Mar 22, 2009 | 06:56 PM
ThunderOZ's Avatar
Ok got that fixed, new issue.
It doesn't seem to be logging anything. It says that it is but I don't see anything happening...
Old May 5, 2009 | 09:42 AM
Live4Redline's Avatar
Thunder... did you ever get this working or did you give up? Because i have a great deal of experience with it if you need a hand.
Old May 5, 2009 | 10:09 AM
ThunderOZ's Avatar
Yea I got that part working but I can't log anything...
Old May 9, 2009 | 01:59 PM
jrelyea828's Avatar
i had the exact same problem, except i cant get ecuflash to work for some reason. I re-installed evoscan when I got that error and it ended up working fine. as for ecuflash... i got all the master definition files downloaded and saved to the proper places, but it still says theres no definition for my car. which is bs.
Old May 10, 2009 | 01:18 AM
ThunderOZ's Avatar
Well that error is gone now. EvoScan opens up, runs, and clears codes. It just can't read codes or log for some reason... It say's it has a connection but nothing happens.
EcuFlash on the other hand works perfectly fine.
Old May 10, 2009 | 09:24 AM
Which Ecuflash are you useing...? Becouse you need to be using ver. 1.29 for the lancers. The newer versions i've had trouble getting to work.
What you have set for your baudrate? Mines setting at 15625.
Old May 10, 2009 | 10:18 AM
senate6268's Avatar
I used to tell everyone the same thing. I'm currently using v1.41 and haven't had any problems reading, flashing, etc.
Old May 10, 2009 | 11:52 AM
4g94T's Avatar
What's the difference with 1.29 and 1.41?
Old May 10, 2009 | 12:18 PM
senate6268's Avatar
Lots of bug fixes and support for newer vehicles. There were also changes in how the endian values are interpreted in the metadata files. You can read through the revision history here, if you want:
http://openecu.org/index.php?title=EcuFlash
Old May 10, 2009 | 12:46 PM
I have both 1.29 and 1.41 on my PC for different cars. It just seems that some versions work better for certain cars then others. Just like I can't read 3G V6 Eclipses on 1.41 but i can on 1.29 for some reason. I'm sure there's a way to get it too work... but straight from the download 1.29 works like a charm on my lancer.
Old May 10, 2009 | 05:35 PM
ThunderOZ's Avatar
Yea I'm using EcuFlash 1.41 with no issues
How do I check that?
Old May 10, 2009 | 05:55 PM
senate6268's Avatar
It's one of the settings seen here in EvoScan:
Old May 10, 2009 | 07:11 PM
^ Ya... like he said. lol
