Innovative Wideband o2 in replacement of STOCK
Old Apr 7, 2009 | 07:50 PM
Jonas's Avatar
Just bought the innovative wideband o2 LC1, and was reading the manual and saw that you can use the Wideband o2 sensor in place of the stock using one of the analog output as a signal into the EFI. anyone done this?
Old Apr 7, 2009 | 07:57 PM
OZ Rally's Avatar
Seems like it would be easier and cheaper instead of making a new bung.
I would like to know too since I will be buying one soon.
Old Apr 10, 2009 | 12:51 AM
sykou's Avatar
It can be done. You use the analog output one to send the signal to your ecu. You will have to mount the existing o2 sensor somewhere tho because the ecu checks to see if the heater circuit on the o2 sensor is working. So might as well get a new bung installed. About two feet upstream from the pre cat o2 sensor is a nice place as you can run the sensor thru the existing grommet under the car.
Old Apr 10, 2009 | 07:21 PM
ThunderOZ's Avatar
I would just get a bung welded into the down pipe to be honest. Why exactly did you want to make it put out the stock style signal?
Old Apr 12, 2009 | 08:43 PM
Jonas's Avatar
eh Lazy... don't want to take the DP off to weld a new bung on it... just want to remove the OEM O2 sensor and plug in the Wideband o2... yeah inkow sad eh...
Old Apr 12, 2009 | 10:46 PM
jdparadee's Avatar
okay, newbie question, but what does a wideband sensor do? i have seen them advertised but don't really know what they are for,
Old Apr 13, 2009 | 12:22 PM
ClixT's Avatar
lots of things but mostly a/f ratio.
Old Apr 13, 2009 | 01:35 PM
ThunderOZ's Avatar
Ok so I'm guessing you want to remove the second O2 that goes into the cat, and remove the cat...
Old Apr 13, 2009 | 01:36 PM
ThunderOZ's Avatar
It's like 4 bolts
Old Apr 13, 2009 | 06:31 PM
Jonas's Avatar
yes it is... just don't feel like jacking the car up and crawling underneath... sigh... i guess i'll just DO IT!!!
Old Apr 15, 2009 | 11:58 AM
ThunderOZ's Avatar
Just do it It only takes a few minutes.
Old Apr 15, 2009 | 01:14 PM
link62's Avatar
hes being lazy lol
Old Apr 15, 2009 | 04:17 PM
Jonas's Avatar
=) yeah i know... sad thing... my dad's a welder... hahahahha eh guess while i'm under i should pull the motor mounts and fill them as well... I just installed a new clutch and fly and the motor mounts just about sucks...
Enclavet
May 6, 2016 08:26 PM
Giuna99
Apr 17, 2016 07:35 PM
3vo|3oost
Apr 4, 2012 05:39 AM
evo jason
Jan 7, 2012 04:25 AM
empirepb210
90
Nov 11, 2009 11:22 PM
