what oil to use?
Old May 18, 2009 | 10:38 AM
kamillionaire5's Avatar
what oil to use?
should i get 5w-20 or 10w-30 ? i live on long island. any suggestions on the oil filter?
Old May 18, 2009 | 10:44 AM
lancer0220's Avatar
5w-20 is whats recommended, i used 5-30 recently because it was onsale and all that was available. i use k&n oil filters, mobile 1 fully synthetic. mobile 1 oil filters are pretty good also.
Old May 18, 2009 | 04:33 PM
is synthetic oil OK to use for a brand new car?
Old May 18, 2009 | 04:38 PM
GRNCT9A's Avatar
once you go synthetic, you cant go back to conventional. Or its recommended that you stay synthetic.
Old May 18, 2009 | 05:12 PM
4g94T's Avatar
source?
Old May 18, 2009 | 05:26 PM
1lancer's Avatar
thats what someone told me to, that if you go synthetic you have to stay synthetic. can someone say for sure ......thanks
Old May 19, 2009 | 01:40 AM
cRc`22's Avatar
all of these questions were answered already in other threads.. you guys can do a search if youd like..
Old May 19, 2009 | 06:38 AM
anbuzero's Avatar
^wut he said. but IMO go fully synthetic and dont worry. just look at the specials at autozones and pep boys and go with w/e filter is with the special usually bosch or k&n. but as said above once you go fully synthetic do not go back to conventional. synthetic from my experience cools better and lasts longer than conventional which is good if you are a little past due on an oil change.
Old May 19, 2009 | 07:09 AM
apagan01's Avatar
false,
you need to get facts before spreading false info in the forums, it is totally incorect that statement.
i understand that one can be miss informed easilly with so much info out there, but please be carefull
i have many many customers that were using dyno oil for over 50,000 miles and they decided to go and give synthetic a try,, what will hapen is the syntetic willl strart cleaning all that gunk that was build up for all those years with dyno oil.
i reccomend in this case to check your oil level weekly and change the filter in between to help clean ,, or do a flush before changing to synthetic.
Old May 19, 2009 | 07:11 AM
apagan01's Avatar
for evo x and regular lancers
Old May 19, 2009 | 07:44 AM
dvscore's Avatar
^ Thats the good stuff.
Old May 19, 2009 | 09:11 AM
apagan01's Avatar
indeed
Old May 19, 2009 | 12:15 PM
4g94T's Avatar
I use Amsoil RD30. Good stuff
Old May 19, 2009 | 12:29 PM
glbg's Avatar
For new and\or low mileage car, is there an advantage using Sythetic if you regularly change the oil every 3k?
Old May 19, 2009 | 12:30 PM
EngRWW33's Avatar
no
