trouble with 1.3 tactrix cable
Old Aug 8, 2009 | 05:10 PM
bluelancer20028's Avatar
i can pull my rom with no problem but i can not put anything on ecu from ecuflash . ecuflash keeps giving like a error and i can hear the ecu click . so if anyone has any advice im open for suggestions.
Old Aug 8, 2009 | 05:23 PM
[19:16:27.000] sending init sequence 1 (0003)
[19:16:28.031] got 0x05 response
[19:16:28.031] sending init sequence 2
[19:16:28.046] got 0x1B response
[19:16:28.046] sending init sequence 3
[19:16:28.421] entering bootloader
[19:16:28.437] sending kernel size (4420)
[19:16:28.453] sending kernel load address (0xFFFF7000)
[19:16:28.453] uploading kernel
[19:16:29.171] verifying kernel checksum response
[19:16:29.171] kernel valid
[19:16:29.390] kernel get version
[19:16:29.406] rkrv: preamble 1 error
[19:16:29.421] reading kernel comm buffer size
[19:16:29.625] reading kernel flash buffer size
[19:16:29.843] interface close
That is the log from ecuflash
Old Aug 8, 2009 | 05:25 PM
senate6268's Avatar
What version of EcuFlash are you using? What is your ROM ID? If you can read your ROM then you should be able to flash your ROM as well.
Old Aug 8, 2009 | 07:15 PM
03lances's Avatar
Not trying to insult you or anything but you have the cable with the bootstrap correct? I think there is one cable with just the obd plug for logging and the other with the white connector as well needed to flash.
Old Aug 9, 2009 | 06:12 AM
i had the version before 1.42 and i have went to 1.42 as of this morning and i have the 1.3 cable with both connectors.
Old Aug 10, 2009 | 05:46 PM
still having the same problem rom id is 86640007
Old Aug 12, 2009 | 10:17 PM
03lances's Avatar
Does your rom you pull look fine in terms of numbers where they should be? or do they look jumbled?
Old Aug 17, 2009 | 03:15 PM
ClixT's Avatar
EDIT: problem fixed
Old Aug 18, 2009 | 07:23 PM
still having the same problem senate fixed it but still having reflash problem
Old Aug 18, 2009 | 07:41 PM
ClixT's Avatar
maybe you have the same problem as i do.
make sure you have OEM ecu..
Old Aug 19, 2009 | 04:28 PM
how would i find out??? what did you do?
Old Aug 19, 2009 | 05:38 PM
ClixT's Avatar
well mines pretty straightforward.. i bought this flashed ecu and installed it..
then i realized that i have the flashed ecu, installed the oe one, then it worked.
edit: try this
maybe your ecu is locked..
Old Aug 19, 2009 | 06:39 PM
senate6268's Avatar
Originally Posted by ClixT
try this
Definitely worth a try. I'm pretty sure this is meant for ECUs that are locked due to licensing (EcuTek and other flashers do this).
Thinking back I just realized that I was getting this same error when trying to flash my Evo ECU for the first time. I downgraded to EcuFlash v1.29a and all was well. Might want to give that a try, as well.
Old Aug 19, 2009 | 08:58 PM
anyway i can get v 1,29a?
Old Aug 19, 2009 | 10:56 PM
ClixT's Avatar
from senate: https://www.evolutionm.net/forums/la...ster-list.html
