View Poll Results: Which intake should I use!?
Fujita: Short Ram Intake system
2.04%
Road Race: Short Ram Intake 09+ 2.4L
14.29%
Injen: Cold Air Intake for 2.4L
51.02%
K&N: TYPHOON COLD AIR INTAKE
22.45%
K&N: Drop-in Filter
2.04%
HKS: Drop-in Filter
4.08%
Others
10.20%
Multiple Choice Poll. Voters: 49. You may not vote on this poll
Help: Intake for 09 GTS
Old Oct 4, 2009 | 01:02 PM
momokoo's Avatar
Hi:
I'm planning to upgrade my stock intake... but this is my first time come across with this.... so I need your input...^^
please notice that,I live in Vancouver, BC where it will rain and snow alot in the winter...
1) Fujita: SRI for 2.0L - OUT OF THE LIST - TOO MUCH ISSUES WITH THIS
http://www.fujitaperformance.com/pro...m/Default.aspx
2) Road Race Motor: Short Ram Intake 09+ 2.4L
http://www.roadracemotorsports.com/s...roducts_id=296
3) Injen: CAI for 2.4L - claim a 11hp and 10ft/lbs of torque gain
4) K&N: Typhoon Air Intake [$320 CAD + labour]
- Claim a 6.73 horsepower gain @ 5100RPM
5) K&N: Drop-in Filter
6) HKS: Drop-in Filter
7) Other: Are there any suggestion?
Old Oct 5, 2009 | 08:18 AM
momokoo's Avatar
Thanks Answer_1..!!
Old Oct 6, 2009 | 09:51 AM
momokoo's Avatar
Any input is appreciated..!!
Old Oct 6, 2009 | 10:09 AM
momokoo's Avatar
- Delete
Old Nov 23, 2009 | 03:12 AM
Me-So-Bishi's Avatar
Heres what i did and you should do the same, first i relocated the battery to the trunk cost me a whole 20$ to do that. By relocating the battery it frees up alot of room under the hood and reduces the weight up front in the engine bay. also i dont know if you have looked at most of the intakes but the filter is usually mad close to the exhaust manifold which isnt good. i bought the weapon-R secret intake and its hands down the best ive ever used, if you go on ebay you can find it for about 200$ shipped, and its the only intake that ive seen that you can position once you have relocated the battery and the filter sits behind the headlight. i have tested the intake temps and the temp draastically dropped when moved away from the exhaust manifold. To each his own though but i did this to my car and im just passin the idea on to you and anyone else who wants to do it.
Old Nov 23, 2009 | 08:24 AM
thenuzz's Avatar
I got the Injen CAI and love it. I also got the hydro filter cover which was another like $25. it waterproofs the filter so water does not get inside. the pipe runs down the drivers side and goes right in front of the drivers side wheel. if you have a GTS model you will have to relocate the oil cooler (brackets included) te instructions say to take off the front bumper. i dont recommend that. what i did was take off the wheel and housing and got back in there that way. itook me about an hour and a half but thats because i was taking my time (BEER) and first mod on a car i have done (I use to mess with sport bikes) but it was simple.
Old Nov 23, 2009 | 10:04 AM
momokoo's Avatar
Thanks for your input..!!
Was that hard to install..?? I'm kinda thinking SRI since it's less work to clean the filter and less chance for hydro lock (I live in Vancouver, where here are alots of rain...)
Thanks !!
Old Dec 7, 2009 | 06:13 PM
qJai's Avatar
dun think that hydrolocking will be an issue, unless u guys get floods alot, but just a note, k&n typhoon, no need for labour, pretty easy install diy. u probably dont need any labour for any of them but injen will be more trouble since u gotta relocate the battery and stuff
Old Dec 8, 2009 | 03:08 AM
thenuzz's Avatar
with the Injen CAI you do not have to relocate the battery (unless you want too) but the GTS has a oil cooler in front of the drivers side wheel where the filter will be going. Injen supplies the bracket for you to relocate that a little for the filter to fit. I installed it and it took about an hour and a half. i DID NOT remove the bumber like the directions said too. i just went in through the wheel well. pretty easy really. just wanted to clear things up.
Old Dec 8, 2009 | 07:31 AM
lancer0220's Avatar
yeah if you remove the wheel and just go through the welll its not bad i took my bumper off the first 3 times i did this (had the 2.0 intake installed it, uninstalled it then installed my 2.4l) but now when i dust off my filter i just go through the wheel well.
Old Dec 8, 2009 | 08:15 AM
momokoo's Avatar
thanks for your input...^^ I'm waiting for more products for the 2.4L
Old Dec 8, 2009 | 11:04 AM
lancer0220's Avatar
honestly i would wait for takeda to make a 2.4l intake their SRI design is great i love the way it looks. that is if your worried about rain snow etc.
Old Dec 8, 2009 | 11:12 AM
momokoo's Avatar
actually I'm fine with a K&N 2.4L... haha~ if they are planning to develop one
Old Dec 14, 2009 | 09:05 AM
KaizLancer's Avatar
i have the fujita SRI, took a freakin year to get it replaced (maf sensor gap) now the new one works great, although i might switch over to a Injen or Weapon R CAI
Old Dec 15, 2009 | 01:08 PM
lancer0220's Avatar
dont go with weapon R , havent heard any good things about that intake.
