evo ecu swap with 399 maf
Old Feb 8, 2010 | 09:08 PM
  #46
JRR's Avatar
JRR
Originally Posted by senate6268
Ok. Put the 399 values back in. You can then either lower the MAF scaling in the lower Hz to help your idle or take a look back at your latencies. It will take some time for your trims to stabilize.
this is true and what i had figured as well since i think i have exhausted pretty much all the possibilities.
im working on them now as we speak. the only thing left that im going to try is use the lower part of the 501 and then the uppers of the 399. basically making a hybrid between the 2.
josh
Old Feb 8, 2010 | 10:09 PM
  #47
03lances's Avatar
Sorry I havent been able to post my values, my stupid laptop (although working better now :P) will not connect online so until I can get online with that I cant post my values
  #48
JRR's Avatar
JRR
kewl thanks
we will get this thing tuned in pretty good soon enuf.
josh
Old Feb 8, 2010 | 11:11 PM
  #49
03lances's Avatar
Ok got my laptop back online, here are what I am set at. Injector scaling is 412, My idle is plenty stable but after it warms up it has as ever so slight stumble every so often but I hope it helps
Old Feb 9, 2010 | 07:07 PM
  #50
senate6268's Avatar
03lances is running the stock 399 MAF values and is up and running, which means that you'll need to circle back around to adjusting your latencies. Get 'em dialed in and you should be good to go. Best of luck getting it purring like a kitten!
Old Feb 9, 2010 | 07:38 PM
  #51
JRR's Avatar
JRR
i tried them today and it still wont idle worth anyhting other than low to mid 10's. i cant for some reason after all that i have tried to get my idle out of the 10's and back to where they should be. is there another setting in hte ecu for idle or somehitng? got a couple of mechanics thinking that it might be an IAC but it idled fine with my stock lancer and 501 maf.
josh
Old Feb 9, 2010 | 08:00 PM
  #52
senate6268's Avatar
josh
There are tables in EcuFlash for idle RPM at neutral and idle RPM in drive. You can adjust that if you want, but it shouldn't be necessary. Can you post a screenshot of your current latencies?
Old Feb 9, 2010 | 08:11 PM
  #53
JRR's Avatar
JRR
here are my latencies. mine is the one on the left and 03lances is on the right that i flashed in today. all with the stock 399 maf values.
josh
Old Feb 9, 2010 | 08:14 PM
  #54
JRR's Avatar
JRR
this mite look a little bit better.
josh
Old Feb 9, 2010 | 09:00 PM
  #55
03lances's Avatar
I dont know how much this would matter but I have all stock piping from an evo 9, the only difference is I have a cone filter instead of the stock airbox. Stock 9 intake pipe, UICP, FMIC, LICP, evo 9 bov, and stock recirc pipe, plus i have ported my intake manifold.
Old Feb 9, 2010 | 09:02 PM
  #56
03lances's Avatar
Could timing play a role? Did you cut your ecu wires or swap the pins? If you have to maybe swap in your stok ecu and tune for the 399 then plug those values into your evo ecu.
Old Feb 9, 2010 | 09:44 PM
  #57
JRR's Avatar
JRR
i swapped the pins since i finally figured out how.
the only thing that is really different with my setup is that im running all injen pipes (upper, lower, and hard intake) with the evo 8 stock bov and a 4" filter and my rrm ported im and tb.
and i never looked at timing i left that all stock from the evo base setup for the 94170008 rom.
josh
Old Feb 9, 2010 | 09:51 PM
  #58
03lances's Avatar
With my evo ecu I pasted over my timing maps for like the first couple collumns, so the idle would have the same timing as my stock ecu. Never ran with the stock evo timing so not sure if this would matter but maybe its worth a try
Old Feb 11, 2010 | 06:03 PM
  #59
JRR's Avatar
JRR
ok so i changed the first couple of columns on the timing still with no luck. adjusted the BISS screw today and its still rich but at least it will idle. working on getting my frot o2 sensor back in this weekend and i will then go from there.
the only other thing that i can think of that it might be is my IAC, but idk. ill have to remove it to see and those arent cheap!
josh
Old Feb 11, 2010 | 07:14 PM
  #60
03lances's Avatar
Wierd its gotta be something with your ecu or your maf itself you would think? I mean those are the only things you changed before the issue. idk
