how to log your AEM EUGO with evoscan
Old Apr 6, 2015 | 01:31 PM
  #121
6spdlegend's Avatar
Originally Posted by Biggy VIII
Has anyone figured out correct formula for accurate logging?
bump- just pulled the trigger on an AEM UEGO also and would love to know if others have had luck w/ the formula approach...
Old May 3, 2015 | 12:41 PM
  #122
6spdlegend's Avatar
I've tried both 0.03913*x+10 and 0.03913*x+9 and I'm seeing a big variance between the gauge and the output in EvoScan - at idle I'm seeing 12-14 on the gauge and only 10.x in EvoScan....
Old May 3, 2015 | 12:57 PM
  #123
6spdlegend's Avatar
Also- how is the requestid of 3c determined? the value looks so off i'm starting to think that i may have to use a different requestid?
Old May 3, 2015 | 02:27 PM
  #124
jakermeister's Avatar
The request is determined by the address in the rom. You may need to look it up in your mut table. I've found that the formula in evoscan has been pretty good and left it.
Old Oct 24, 2015 | 10:32 AM
  #125
Evo9_Dubai's Avatar
Hi Guys, sorry to bring this back up.
I am logging through both USB & Direct. Also using +10, although it seems to be off once it goes less than 10.9 AFRs or so. Has anyone got it working perfectly yet?
Old Sep 22, 2016 | 12:07 PM
  #126
mines5's Avatar
What pin should I use for evo 7 manual JDM to log aem uego ?
Old Sep 22, 2016 | 02:54 PM
  #127
4b11slayer's Avatar
So after cutting pin 75 of evo ecu add the white (aem serial) wire and solder it together and not use other end of wire from 75?
Or do you Solder both cut wires and add in the aem wire?
Read through 9 pages I didn't find a answer.
Old Sep 23, 2016 | 12:46 AM
  #128
mines5's Avatar
Bump
Old Feb 12, 2017 | 10:53 PM
  #129
merlin.oz's Avatar
pin 75
Old May 12, 2017 | 10:03 AM
  #130
Sickmode7's Avatar
pin recommendation
Hey what pin would you recommend for the EVO 456 ECUs as we don't have the rear lambda.?
Originally Posted by darkmitsu
How to log your AEM EUGO with Evoscan
Prerequisites...
-Tactrix Cable
-AEM EUGO wideband (already installed and working)
-Evoscan (installed on a laptop so you can plug into the car using the tactrix cable to take logs)
-Lancer evolution 8 ecu
Step one
cut wire connecting to pin 75 leaving some wire hanging out of the ECU , you will tap into this wire with your aem gauge . Your aem gauge will have red , black , blue , and white wire coming out of it . The red and black are, red for power, and black for ground these 2 wires power your aem gauge, the white wire is an analog output wire you will be connecting this wire to the wire going into pin 75 on the ecu.
step two
Launch evoscan
step three
Right click any scanning object in the list and click the option edit data item.
step four
click add new item in the bottom left hand corner , new item option will apear on the right hand side where you will input all the data from the next screenshot.
step five
display: AEM UEGO
LogReference: AFR
RequestID: 3C
Eval: 0.03913*x+9
Unit: AFR
MetricEval: 0.03913*x+9
MetricUnit: AFR
ResponseBytes: 1
GaugeMin: 5
GaugeMax: 20
ChartMin:5
ChartMax:20
ScalingFactor: 10
After inputing this information , click OK .
I tried this 0.03913*x+10 formula but my AFR display on the Gauge and what was displayed on the log were off by 1 so I edited the formula to 0.03913*x+9 ...
step 6
You will now have a option within evoscan to select AEM EUGO and can log your wideband now without having to plug in an extra serial cable ...
step 7
Now open ecuflash and edit the table below to 0x0009 to get rid of the rear o2 heater cel...
Old Jul 6, 2017 | 11:33 PM
  #131
seeaich's Avatar
Anyone ever get a solution for this? I have a JDM 8mr and would love to pin the wideband in but there is no rear 02 listed under pin 75.
Originally Posted by aquaplane
I've an AUDM Evo IX, and the ecu pin outs aren't the same as USDM. Does anyone know which pin out i should be cutting into?
AUDM Evo ix ecu looks pretty much like the jdm 8mr pin outs. Am I right to assume that I'll just cut into #75 wire on my ecu and it will be the same thing?
Old Jul 7, 2017 | 03:35 AM
  #132
Sickmode7's Avatar
hey. I have an evo 4 with the 6 ecu and I just connected the line to pin 75 and it work. I was able to get data on evoscan. And pin 75 on evo 6 n 4 has nothing. Hope this helps.
Old Jul 7, 2017 | 07:09 AM
  #133
mines5's Avatar
Originally Posted by Sickmode7
hey. I have an evo 4 with the 6 ecu and I just connected the lime to pin 75 and it work. I was able to getting data on evoscan. And pin 75 on evo 6 n 4 has nothing. Hope this helps.
Thanks bro..
1 more question..
the evo 5 and evo 6 wiring is the same ?
Old Jul 7, 2017 | 10:30 AM
  #134
Sickmode7's Avatar
reply
Thanks bro..
1 more question..
check this schematics out if this attachment doesn't work it should be on the forums.
File Type: xls
Old Jul 7, 2017 | 11:47 PM
  #135
mines5's Avatar
Thanks buddy..
