View Poll Results: Upgrade fuel injectors on slightly modified N/A?
Pet it and make it squeal 250cc
0%
Voters: 3. You may not vote on this poll
Upgrading stock injectors on N/A
I'm running 232cc/min>>> this is via ecuflash.
It also has values for voltage latency, high octane map, and low octane map. Since I have another 8cc or so to play with... any recommendations on what to edit to trim fuel economy? Also, would running a full 240cc do anything useful?
ok. Would I be able to tweak larger injectors to work with my current setup, and then scale them up as I need to? Or are the injectors pretty much the last thing to upgrade after a bored throttle body, intake manifold, fuel rail, aftermarket coils? Or is it really only worth it with major mods like forged pistons and rods, turbo, and/or nitrous?
Just exploring possible mod routes without building up the engine or going turbo, basically trying to squeeze a few more hidden horses out of hiding while keeping it N/A...
no kidding. cool. Just wanted to make sure I beat the horse dead if and when I ever need to replace any injectors I'll stick to stock size. Didn't know if I should go and increase the size when and if I needed to replace them from failure/etc. Thanks for all the good info!
Stay outta the pedal lol. Seriously though if you really wanted to you could use ecuflash to run your car in open loop cruise then you could adjust cruise to be at around 15.2 afrs which I am told is the best mileage ratio.
Then again if you dont have a wideband that might be difficult to do
The fact remains that you would be wasting your money since your current stock injectors are not being out flowed. You won't need larger injectors anytime soon. Even turbo Lancers can run 5-7psi on stock injectors, if that tells you anything to what the stock injectors can provide.
The reason why i'm asking about higher flow injectors, is that I'm seeing NEW hihg-flow (250cc-840cc) ones on eBay for cheaper than I can get USED stock injectors>>> So I wanted to check and see if I can get the larger injectors and make them work, or if I have to stick with the stock injectors.
Also, when upgrading injectors, is it worthwhile to get a high-flow fuel rail, or are those overrated unless pushing serious hp?
We have a .pdf file located on the website: http://www.deatschwerks.com/docs/ser...order_form.pdf
Print it off, and write at the top EvoM Forum Special Service.
It is $19/injector and free shipping back to you. The payment information is located at the bottom. Circle the basic service and in the additional information section write in upgrade to forum special.
Send them in and we'll get them turned around back to you.
and updated link for the order form is here: http://www.deatschwerks.com/images/s...order_form.pdf
DiazEvolution
10
Apr 29, 2010 12:46 AM
