Spark Plug Gap On A N\A
Old Aug 24, 2010 | 04:32 AM
mci2727's Avatar
I've searched and have found that alot of you turbo guys are running a gap inbetween .25-.32.
I drive a N/A and am running that NGK gap of .44 and wanted to know if anyone knows the rule if I can gap tighter for better results on a N/A or if I need to stick to factory specs?
Old Aug 24, 2010 | 02:50 PM
mci2727's Avatar
So with a little further research I think I've found the answer if anyone who knows can conform?
A: Use the biggest gap you can without cuaseing problems with misfire.
I.E. If I'm not having misfire problems with the .44 gap then I should stick to that gap as a larger gap will make a cleaner burn.
Is this right?
danny1058
Lancer Engine Management / Tuning Forums
Jun 19, 2016 08:37 AM
rEvolution420
Oct 5, 2007 08:31 PM
zcool1986
Lancer Engine Tech
Sep 8, 2007 12:22 PM
RalliArtEvoVIII
18
May 6, 2005 10:35 PM
kansaslancer02
Sep 5, 2004 01:31 PM
