Cant read/ write to ECU..
Old Dec 12, 2010 | 02:39 PM
Mitsu.kid.02's Avatar
Ok, so after i blew a main fuse, i replaced it, car runs fine, no problems. I can log in EvoScan so i figured the ECU is working and is ok. I go to try to Re-Flash the ECU and it wont work. It sends some sequences, then it stops and tells me it wont work.
When i blew the main fuse, the re-flash cable was not plugged into the ECU/ however the regular OBD-2 connection was, so i doubt i fried the cable because everything reports back in EvoScan with no problems. did i break the ECU? is there a relay or fuse somewhere that i may have blown before the ECU? i checked all the fuses were ok. Any ideas?!?
Here is what happens:
sending init sequence 1 (0001)
sending init sequence 1 (0003)
sending init sequence 1 (FFFF)
"no response to any known code"
Since it works in EvoScan, im thinking i shorted out the cable or something? If i shorted the ECU the car wouldnt run im pretty sure right?
Old Dec 13, 2010 | 06:52 AM
Any ideas guys? its important i figure out whether i need a new ECU or just a new Re-Flash tactrix cable becuase im still in the process of tuning
Old Dec 13, 2010 | 09:06 AM
03lances's Avatar
Does your cig lighter still work mitsu?
Old Dec 13, 2010 | 09:09 AM
Yeah it does, why would that matter j/w! Well actually let me check, becuase i also had my garman charger in the cig lighter at the time, and now that wont work, i cant find a way to open it up to see if the fuse blew in the charger unit.
EDIT:: However i can put my power inverter in the cig lighter and it powers up ok, so im guessing the cig lighter does still work
Old Dec 13, 2010 | 09:14 AM
03lances's Avatar
I asked that because most cars will have the fuse for the cigarette lighter also be the fuse for the obd port. I was curious if we could still log with a blown fuse but not actually extract or write information. It was a shot in the dark
Old Dec 13, 2010 | 09:21 AM
I see what your sayin, damn i checked all the fuses under the hood, and under the dash, there all fine :-(
Old Dec 13, 2010 | 09:23 AM
03lances's Avatar
Have any friends close by you could try to read there ecus?
Old Dec 13, 2010 | 09:26 AM
No damn.. i have a galant, but do they have a reflash port?
Old Dec 13, 2010 | 09:36 AM
03lances's Avatar
Depends on the year but it should. Did you say you could not write or read? You coul try to just read your galant maybe
Old Dec 13, 2010 | 09:40 AM
Yeah ECUFlash wont let me write to ECU, or even read the ECU. Ok, ill try to read the galant when i get home from work today. Its just so weird becuase when the fuse poped, the OBD-2 connection was still connected but the re-flash cable was not, however now the re-flash cable WONT work, but the OBD-2 cable does because EvoScan works fine
Old Dec 13, 2010 | 09:41 AM
03lances's Avatar
Honestly I am kind of leaning towards something in your ecu fried blocking your ability to read/write but lets see what happens with the galant.
Old Dec 13, 2010 | 09:46 AM
I hope not Ill keep you updated with the galant later tonite, how much do you think a new ECU would cost?
EDIT:: just got a quote from LKQ 150 my cost (work at kia in the parts dept) so i guess not too bad. Ill run the test on the galant tonite
Old Dec 13, 2010 | 05:06 PM
03lances's Avatar
Thats not too bad then, just a little more than another cable would be anyways
Old Dec 13, 2010 | 08:22 PM
Alright bro, so i tried to read from the galant ECU and got the same exact code. What do you think? should i try a cable first? the OBD-2 connection smeels really bad, like a bad battery, its horrible Is there anyway of testing my ecu to confirm its a bad cable?
EDIT:: Opened up my tactrix cable by removing the exterior plastic. Once i opened it up i saw the things on the circuit board that just plain fried out, big black spot with a line going through it on one side, and on the other, one peice of metal actually melted. Ill post pics in the morning!
Old Dec 13, 2010 | 11:01 PM
03lances's Avatar
Well that sounds confirmed to me man. New cable it is
