Definition file for ROM# 94950001?
Old May 31, 2011 | 01:18 PM
Chunked's Avatar
Hey guys I've got a ROM that isn't on the master list of definition files and I was wondering if anyone's got/made a definition file for it?
I've worked through the entire list of definition files to see if any will match perfectly but no dice :'(
2004 OZ Manual, ROM# 94950001
Here's the HEX if anyone wants to make an xml for it.
Thanks in advance!
File Type: hex
Old Jun 5, 2011 | 11:54 PM
Chunked's Avatar
After some searching I've found a suitable xml to be inherited for the ROM.
Located it here: http://forums.openecu.org/viewtopic.php?f=55&t=4210
Quick question though. In the high/low octane ignition maps there seems to be an extra column/row on each axis, load jumps from 100% to 260% and rpm goes from 7000 to 11000. Nothing else seems to be affected in any other set of tables and since the rev limiter's at 6230 and load won't go above 100% without boost it shouldn't affect it right?
We'll see how it goes
File Type: zip
98490000.zip (996 Bytes, 0 views)
Old Jun 7, 2011 | 01:44 PM
caster5610's Avatar
awsome
senate6268
Lancer Engine Management / Tuning Forums
343
May 22, 2026 07:27 PM
EvoIXPilot
Feb 6, 2013 08:55 PM
cossie1
Aug 27, 2008 12:06 PM
MR
Oct 18, 2007 11:46 AM
Zamot
Sep 6, 2007 11:41 AM
