Ecuflash help please
Old Oct 12, 2011 | 03:00 PM
turbotsi's Avatar
Im having trouble viewing maps on my 2002 Lancer ES (ecuflash says its an OZ) ive found several guides online but i keep having the same issue. I set my user level all the way to developer so that i can see everything. But ALL maps are still greyed out and when ever i click on something it tells me " The current map description is invalid or incomplete. Please edit map description to fix the problem and the map will be viewable again" And it i am able to get a map to show something it is in some bar graph form that tells me nothing. How can i get this so that i can edit maps?
Oh i forgot, the ID is 98720010
Old Oct 12, 2011 | 03:04 PM
RoadSpike's Avatar
your rom id is either not defined or when you created it you use the inheriet from base rom method. Either way you need an xml with proper definitions so you can edit the maps. Take your rom ID slap it into google and find one.
Old Oct 12, 2011 | 03:35 PM
turbotsi's Avatar
Ok cool, thank you.. I found a post in here earlier with my rom id that had definition. Ill download that and see what happens
Old Oct 12, 2011 | 04:27 PM
turbotsi's Avatar
Ok, got definitions from here and some i found on google... So what am I doing, puting in missing info or what? Sorry I'm kinda new to ecuflash, all my tuning experiance is with Dsmlink V2
Old Oct 12, 2011 | 04:30 PM
RoadSpike's Avatar
You'll just put the xml file into the right sub folder of ecuflash under program files/ rommetadata/mitsubishi/lancer
just overwrite any file you have in there now no need to keep incomplete data.
Old Oct 13, 2011 | 09:08 AM
turbotsi's Avatar
Thank you so much for the help Spike, i got it all figured out thanks to your advice and Senate6268's list of roms. Now i can start playing around... it almost looks like my DSMLink V3 lol
thndrballl
Lancer Engine Management / Tuning Forums
Dec 31, 2015 01:15 PM
EFIxMR
Jan 1, 2015 05:27 AM
mrwickd123
Aug 15, 2013 12:21 AM
Stradale
Oct 21, 2011 11:04 PM
silverghost
Apr 17, 2009 11:21 AM
