03 Lancer Definition File & Flash Help
I'm currently working on my 2010 Lancer X 4B10 5MT, managed to read the ECU and checked the ROM ID in goldenevo.com, the ROM ID is 57370001. But somehow I couldn't in ECU flash, where "unknown ROM image" error appeared. I believe this is due to there is no definition file for it.
Does anybody here has the definition for this? Highly appreciate for it.
Thanks!
Thanks!
Hi guys i have a 2003 lancer ES 5-speed i recently picked up t40e turbo wrx 440 injectors ext wastegate and front mount intercooler i just got turbo, injectors, wastegate and oil lines finished up tonight i still have to mount intercooler and connect plumbing but I need to know where to hook up the blow off valve vaccum line? ive read the FPR is best place for bov and boost guage but i dunno. I also need to know where to hook up my manual boost controller? And last but not least i have downloaded ecuflash and i need to know where to get the best map for my set up and how to up load it i also need to know which cable i need to hook up my car to my laptop? will a obd11 off of a engine code scanner work? Thanks for any help in advance
im trying to extract senates files to ecuflash and it says my path entered is invalid? what am i doing wrong and which is the right map for an 03 lancer es with Greedy cat back t40e turbo 440 injectors front mount intercooler ext wastegate. also can you tell me where to run my manual boost controller vaccum lines? thank you
senate6268
Lancer Engine Management / Tuning Forums
343
May 22, 2026 07:27 PM
lukas1989
Apr 17, 2016 03:48 PM
dadsgts
May 1, 2010 09:12 AM
