2011 lancer gts turbo question
Old Jan 16, 2013 | 11:43 PM
Simon Pugmire's Avatar
Im wanting to turbo my lancer if I got a stock ra turbo kit would that just bolt up with no problems and no tuning required ( I'll get it tuned eventually )
Old Jan 17, 2013 | 05:26 PM
fiveandahalf83's Avatar
the hardware fits fine. but you cannot use your na ROM. you have to either flash to a evox ROM or swap to the the evo ECU or run a piggy back AEM FIC8.
Old Jan 17, 2013 | 05:36 PM
Panis's Avatar
No, it will be a custom job and you'll need a tune.
Old Jan 17, 2013 | 10:13 PM
Ok but than would I have to change injectors? If not swapping the ecus would be much easier. And I'll be able to do it myself instead of payin for it all to be installed
Old Jan 17, 2013 | 10:39 PM
Risky Guy's Avatar
just a tiny bit of advise, get some help or you are gonna chew off alot.
putting a turbo is gonna be more than just the ecu swap, your going to have to tune it.
plus who knows what other issues you may run into.
hope you can do it, this isnt a small job.
Good luck my man, if you do it props.
Old Jan 18, 2013 | 01:49 AM
LiX's Avatar
LiX
If you haven't done it before better not do it. Seek for professional help.
Old Jan 18, 2013 | 03:33 AM
Panis's Avatar
If you don't swap injectors you're going to have to install a 5th injector setup, and in that case swapping for evo injectors is the better option.
Honestly if you're asking if an RA turbo bolts up no prob you obviously haven't done the research or have the know-how to complete this project. I'm not trying to offend, I'm just sayin.
Old Jan 18, 2013 | 03:36 PM
I have worked a lot on cars my last car was a Mazda protege so this is a huge step up. I've never turboed a car but I am wanting to piece it all together and get the main things installed which is why I'm asking what all I may need I know it will be difficult but I also have my father who's a mechanic helping. I'm planning to put all the main things on than having a professional tune the car so that part is left to them. I live in a smaller town so there is one place in town that can do it and they charge 120 /hr so I figure that money can be used to have it tuned.
Old Jan 18, 2013 | 07:06 PM
Panis's Avatar
For sure. Well over at 9gLancers they have a thread or two that list every part you need for the setup
Old Jan 18, 2013 | 09:23 PM
Thank you so much that's the perfect answer I appreciate your help. Thank you
Old Jan 19, 2013 | 08:48 AM
LiX's Avatar
LiX
More than thread or two. Look my turbo thread on 9gL for example. If you wish you can open your own turbo thread there.
MaddEvo_17
May 16, 2016 12:24 PM
NorCal Lancer
May 21, 2012 11:10 PM
chronotrip21
Nov 12, 2011 06:45 AM
cantcatchme96
Lancer Aftermarket Forced Induction Tech
41
Nov 11, 2011 06:59 AM
kansaslancer02
Lancer Troubleshooting
12
May 21, 2006 11:20 PM
