clutch lancer X from evo 3-6 put
Old Jun 12, 2015 | 04:22 AM
lexa609's Avatar
Hi guys!
I Do swap engine 4b11t from ralliart td04 on Lancer X 4WD
It is possible clutch from evo 3-6 (basket +disk) put on Lancer x
It is possible to put the clutch from Evo(3-6) to lancer x ?
Power 250-280 from horse
Sorry for my English)
Old Jun 13, 2015 | 01:07 PM
lexa609's Avatar
Clutch disk like fit .
Basket is not perfect (I'm not sure )
Old Jun 13, 2015 | 06:46 PM
CamShaft's Avatar
I do not know personally. I would think they would be different.
The only way to be sure is to put them side by side and compare...compare everything! Be very careful.
Torque shouldn't be an issue I would think.
Let others reply before making your decision.
Have an EVO x clutch on standby incase it won't work, then return it. That is if Mother Russia allows.. JK
Old Jun 13, 2015 | 11:48 PM
lexa609's Avatar
Clutch Evo x is not suitable.
Go through the cat bell
Evo x 240mm
Lancer 230mm
Old Jun 15, 2015 | 10:15 AM
LiX's Avatar
LiX
Why you are looking for clutch from older Evo when there are aftermarket clutches for the Lancer? 4B11T can be paired with stock Lancer transmission, so I'm wondering what you are trying to do?
Old Jun 15, 2015 | 03:03 PM
lexa609's Avatar
I need a kit for the Lancer GTS (gearbox W5MBB-1-BFYC ) it fits the disc 230mm
The Evo x 240 mm and the other slots . The clutch won't fit in W5MBB-1-BFYC and not worn on the mainshaft.
I ordered the organic matter from AST but don't know how long you'll live.
Ceramics don't want.
So we went to find some good organics from Evo on lancer GTS (cy4a)
Old Jun 15, 2015 | 03:35 PM
lexa609's Avatar
Engine 4B11T
transmission W5MBB-1-BFYC
Need organic clutch can withstand 280 horses and 400 Newtons
Old Jun 16, 2015 | 11:00 AM
LiX's Avatar
LiX
In this case look for clutch made for Lancer, not Evo X.
For example: Clutch Masters FX200/FX300 or SPEC Stage 2/2+
Old Jun 16, 2015 | 12:51 PM
lexa609's Avatar
Thank you.
Grip suitable from Lancer 9 2.4 rally art.
I ordered from AST
It will not last long holds only 350 nm.(will die after 50 000km)
http://www.clutchmasters.com no data on Newton meters .
simons3z
Feb 12, 2011 01:06 PM
umiami80
42
Feb 25, 2005 10:06 PM
EVOSTEVO
15
Oct 24, 2004 11:14 AM
ReHeat
Sep 2, 2003 08:56 PM
lancer02Josh
Lancer Troubleshooting
Mar 25, 2003 10:49 AM
