Where to start 03 g94 Turbo tuning
Old Feb 15, 2016 | 01:54 PM
LancerMM13's Avatar
Althought title says where to start, I'm not that far behind. I have read and seen many different paths as how to start tuning the Ecu of the g94 stock ecu.
My question is, would it be bad to just flash a stock evo 8 tune onto my 03 oz manual lancer and begin tuning from there after I change injector scaling , MAF Size , MAF Scaling? Will those fuel maps, and timing maps be ok to use as a base with my custom setup. its just a small t3/t4, stock injectors, forged internals.
Ive been told to go with Tephra and use Roadspikes maps but they seem so completely different
Any help is awesome.
Old Feb 17, 2016 | 10:05 PM
Complink's Avatar
I would suggest using roadspikes maps, mainly because the evo maps were designed for the 4g63 and have different knock tolerances. I believe the timing is quite a bit more advanced than the 4g94 can handle.
Old Feb 17, 2016 | 10:07 PM
Complink's Avatar
How much boost are you planning on running? Stock injectors are only good up to 5-7 psi I believe.
Old Feb 29, 2016 | 02:50 PM
marcouxa1's Avatar
You have forged internals and no injectors? you should buy some 440ccs and a 255lph fuel pump or more if you plan on going 10-15 psi! My 440cc max out at 15 psi though.
crf inc.
Sep 3, 2010 02:14 PM
Lusion
May 23, 2010 08:43 PM
(jdM)irage
Lancer Engine Tech
Dec 27, 2009 10:48 AM
bzmotoninja83
Lancer Engine Tech
Oct 29, 2009 07:31 PM
