Missing Definition?
Old Sep 3, 2016 | 05:56 PM
edesparza704's Avatar
Missing Definition?
Hi guys, Ive got a small problem with evoscan and my ecu. I pulled the ecu image from my car 2005 AT Lancer Es but when i try to read it in ecuflash It shows i do not have the definition list. Im using the 1.3U cable with evoscan support. Was wondering if you guys can give me a bit of help.
File Type: hex
Old Sep 5, 2016 | 12:04 PM
Complink's Avatar
Your best bet is to just save that file for the future in case you ever go back stock. If your auto then you will just download roadspikes rom file and modify it and flash it to the car. You won't need the stock file anymore except to reference the stock values.
Old Sep 6, 2016 | 07:08 PM
Roadspikes does have the old maps to reference but I cant get the idle afr to reach a reasonable level. Im assuming the injector settings are all for stock but it rarely goes below 14. During light acceleration it does drop to 12-13 but once slight boost kicks in it leans out immediately to 18. not sure what exactly happens there yet.
Old Oct 4, 2016 | 07:49 AM
f1racingmotor's Avatar
In options in the ecuflash, go to metadata directory and erase this information, and default vehicle too. Close ecuflash and retry...
rartist
23
Jun 23, 2005 12:48 PM
i_love_spool
Canadian Forum
Sep 30, 2003 07:38 PM
