Constant power to cylinder 1 injector
Old Aug 21, 2024 | 09:44 PM
Trac06base's Avatar
So long story short the timing plate on the back of the crank telling the crank timing got broke making the ecu think it was off timing it started running rough then massive misfire on 1 with a circuit 1 code and injector code fixed the timing problem all codes for that are gone now it’s the injector cylinder 1 circuit and misfire codes I pulled the fuel rail and tested it the injector is getting full power to it sending massive amounts (seems to not want to pulse) of fuel I ended up switch the injectors around hoping it would follow and be a bad injector this did not happen it stayed on cylinder one and kept the injector open anytime you had it running or turning over I’m unsure what to check now and I’m frankly lost any help would be awesome I’m think the ecu is good being it still starts but who knows I’ve also not tuned this car at all it’s got a exhaust and intake with the ac deleted so nothing aftermarket would be causing this
Old Oct 6, 2024 | 05:45 PM
Splitting's Avatar
did you replace the broken timing plate? if the vehicle thinks the timing is off it will cause issues
hellomynameis
Jul 24, 2010 06:49 AM
jcsbanks
Jul 21, 2009 03:01 PM
projekt_shocker
Jan 12, 2008 05:43 PM
atilla
Lancer Troubleshooting
Sep 21, 2007 09:05 PM
BlackEv03
Aug 2, 2006 02:34 PM
