Tightening Throttle cable?
Old Oct 17, 2004 | 01:14 PM
Sh0wSt0pp3r's Avatar
I'm seeing alot of lag in my throttle response. It used to pick up quicker than what its doing. I was wondering if there was a way to tighten that cable up, and if you so how?
Old Oct 17, 2004 | 01:24 PM
ambystom01's Avatar
Do a search this has been covered tons of times before. Generally its not recommended to tighten the cable. The slacks there for a reason.
Old Oct 19, 2004 | 09:13 AM
HobieKopek's Avatar
You can take out the slack, just don't let the butterfly remain open AT ALL when you're off the accelerator. It's closed for a reason. The IAC bypass valve is what takes care of idle, so if you leave the butterfly open you're essentially bypassing the stepper motor and your idle air bypass. You'll probably run lean, and you'll almost definitely stall everytime you're at idle, if the car starts at all. As for a how to, I know I posted one, and I'm pretty sure there are several others. Just look for them.
3gevoclipse
Jul 18, 2016 10:13 AM
oneguy
Mar 12, 2008 04:45 AM
dzraduzit
Jul 26, 2007 06:15 PM
SSABII
Lancer Engine Tech
16
Dec 11, 2003 03:47 PM
SpAzCoRe_BeYoTc
25
Oct 11, 2002 09:03 AM
