Idle Flux?
Old Nov 18, 2004 | 12:29 AM
Kelspar's Avatar
Idle Flux?
All has been going well, i decided to install the "homemade" ground kit with 12ga wire and caps. Well finish it, idle seems to drop freq. Like dipping down, when driving at night i notice it more b/c my lights dim until i increase throttle. WHat could be the problem? I know i need a new filter but would that cause bad idle? or how bout oil change? Thanks
Old Nov 18, 2004 | 12:32 AM
lookslikeanevo's Avatar
12g?...why 12g?...i would think 4g would have been better...maybe thats it the problem
Old Nov 18, 2004 | 08:05 AM
Tweak3D's Avatar
wait, wires and caps? whats the rating on the caps? it could be that with the way they are hooked up they are not discharging because they are not getting enough power until you get on the gas. I've never heard of a grounding kit with caps unless it was for a stereo system, not the whole car.
-Justin
Old Nov 18, 2004 | 09:16 AM
GreenPsycho's Avatar
did you remove all the old grounding wires that came with the car or just added new ones? reason i ask is because if you removed the old ones and replaced with the spaghetti 12g ones, then that might cause a problem
Old Nov 18, 2004 | 09:19 AM
twardnw's Avatar
yeah dude, ditch 12g, that's not enough for it, go at LEAST 8g, 4g would be best, and uhh, why are there caps in the grounding system?
Old Nov 18, 2004 | 08:58 PM
Kelspar's Avatar
i bought 12g b/c i read that it was fine and i didnt need a higher (lower) guage wire. Well i will replace them and also if i dont use "caps" (thats what i call them) what should i connect the wires with? you know that caps im talking about? =(o) look like that? Well anyway ill get new wire tomorrow.
Old Nov 18, 2004 | 10:00 PM
ooohhh, you mean crimping caps. thats better, i was afraid (like everyone else) you used capacitors. i would say instead of crimping, just bust out the soldering iron and have at it
btw, did you remove the stock grounding wires or not?
Old Nov 21, 2004 | 10:13 AM
Kelspar's Avatar
solder them to.......what? I cant find crimps for anything below a 12ga. Can i just squeez them between the bolts? or just stretch the caps to fit around them?
browningderek
AEM EMS
73
Mar 2, 2019 08:35 PM
JohnBradley
Feb 16, 2014 01:44 PM
nothere
Feb 10, 2010 06:25 PM
TouringBubble
Aug 1, 2008 07:33 AM
