Is this correct? (Vacuum hoses)
Old Nov 19, 2004 | 01:41 AM
mcbrown35's Avatar
I was lookng at this picture on the RRM website of the colored hose kit. Are the 2 hoses pointed to attached correctly or should they be switched? I swear they are switched on my car...
Old Nov 19, 2004 | 05:27 AM
Dookie's Avatar
Lemme check when I get a break from school. Where is that lower hose running to?
Old Nov 19, 2004 | 05:40 AM
GreenPsycho's Avatar
i don't understand. one is the throttle cable and one is a vacuum line for cruise control, how can they be switched?
Old Nov 19, 2004 | 05:25 PM
4g94T's Avatar
you mean these two? thats how i have them.
Old Nov 19, 2004 | 07:39 PM
honestly, i doubt he has any of them switched, cause first of all, the way the hoses are cut and formed, they only fit one way. secondly, if you switched them, you would be having some engine problems most likely
when i put in my IM and TB, i thought i would have problems with the hoses and where they go, but it was cake to place them back on
Old Nov 20, 2004 | 12:05 AM
urbanknight's Avatar
Moderator
Bomb Squad Unit #02
I was thinking the same thing. It looks like one arrow is pointing to the throttle cable and one to a vacuum hose. The other possibility would show two different sizes of hoses, so either way I don't see how they could be switched. You're fine, unless the check engine light is coming on.
Old Nov 21, 2004 | 10:07 AM
mcbrown35's Avatar
I know which one is the throttle cable..I am pointing to the vacuum line that goes from the side of the intake manifold and i was an idiot and had mine switched.... Yes the car still ran (like crap...this being a MAJOR factor in my stumbling at WOT...), no the cruise control didn't work...
Thanks guys...
mike594x
Dec 11, 2015 06:29 AM
Rich@Orbital
May 15, 2011 07:21 AM
Kracka
Mar 6, 2010 07:23 AM
CA$HMONEY$
Sep 8, 2009 03:45 PM
Viciouz
Mar 26, 2009 08:39 PM
