Intake Mod and Engine Photo *Comments Wanted*
Old Nov 29, 2004 | 09:03 AM
clckwrkorang777's Avatar
Hi guys. Well, I've seen lots of people that have used their stock intake "scoop" (as I call it) to feed cold outside air to their cone filter. I put my scoop back on and fed some cold air from a Cyclone fan into it and it's feeding cold air into the cone! I was happy to achieve this, but I'm not sure how driving at different speeds affects the air flow and temp. Also, I turned my RRM carbon heat shield on it's side to help with the heat shielding process... I'd like some comments on my little design here.
I also did a DIY grounding kit, and here is a shot of my new engine bay!
Thanks a lot for any comments and suggestions!!!!
Daniel
Old Nov 29, 2004 | 09:10 AM
lookslikeanevo's Avatar
i mean its a filter?...what kinda comments are you looking for? im not too big on those winwshield wiper lights...other than that everything looks good and normal
Old Nov 29, 2004 | 09:12 AM
Oh sorry I meant, I had just the filter before, but I put the stock intake scoop back on... presumably to feed cold air, I was wondering if anyone could back up my theory.
Daniel
Old Nov 29, 2004 | 10:25 AM
Blacksheepdj's Avatar
Should work. I had a filter with no scoop, and I could feel it choking for air. Sadly, I sold my stock intake, so I didn't have the scoop to put back on.
Good job of DIY.
Old Nov 29, 2004 | 10:27 AM
Thanks alot man! I do feel a little bit more pull and noise, but that also might be the mod placebo effect lol.
Daniel
Old Nov 29, 2004 | 03:08 PM
ghostrider's Avatar
Well it can only help that you get more air flowing in by using the air dam. And as for turning the heatshield so it's in the way of the block, that's the first time I've ever seen the heatshield actually look useful! Props on the modified design. It may not even give you 2-3 hp, but at the very least your intake is as efficient as it can be.
Old Nov 29, 2004 | 03:30 PM
Thanks for the comment! The intake scoop moved a bit while I rev, so I zip-tied it down lol it works much better now.
Daniel
Old Nov 29, 2004 | 03:31 PM
pgmike's Avatar
good job daniel, made the most out of what you got
Old Nov 29, 2004 | 03:38 PM
Jmorin's Avatar
I think your a crazy cracker! good job man.
Old Nov 29, 2004 | 04:11 PM
ambystom01's Avatar
Nicely done, I'm definitely gonna do that as well, might as well get my filter running its best.
Old Nov 29, 2004 | 04:14 PM
For anyone doing this with an RRM heat shield you *MAY* have to cut a small peice off to fit.
Thanks for the props gentlemen
Daniel
Old Dec 7, 2004 | 02:47 PM
Ok, so I found the gains to be minimal (make that nonexistant), and my uncle and I are brainstorming ideas. I was wondering if a peice of "flexpipe" could run up to the filter to provide cold air... Has anyone tried this????
Daniel
Old Dec 7, 2004 | 02:48 PM
pgmike's Avatar
yeah, i dont remember who exactly it was tho, i think it was urbanknight, but could be wrong
Old Dec 7, 2004 | 04:40 PM
blacklancerr's Avatar
https://www.evolutionm.net/forums/sh...2&postcount=20
check that out...
Old Dec 7, 2004 | 04:55 PM
Thanks alot bud! But I wouldn't be relocating my battery. My funnel would be exactly where his hole in his heat shield is. BTW guys, do you think putting the filter down in the bumper (secured of course), then attaching to the flexpipe and attaching the flexpipe to the MAF would be good? Like
Filter to flexpipe to MAS adapter to MAF? Is that how it goes?
Would that be like a ghetto cold air or what lol!
Daniel
