RRM Piggyback & cold weather
Old Dec 20, 2004 | 10:21 AM
iyi0521's Avatar
I Installed my piggyback in april of this year and it hadnt been cold since then until about a month ago. Since it has been getting cold i have had a problem with a CEL. When the engine is warm and the air temp is cold (less then 45 deg) the idle will drop to roughly 500 rpm and it will throw a code, RICH. Now i am assuming that it is the piggyback because that is the only engine mod i did since this time last year and i did not have this problem last year. If somebody has had this problem and it wasnt the piggyback let me know.
Old Dec 20, 2004 | 03:17 PM
Blacksheepdj's Avatar
Try resetting the ECU (unplug the battery for a few minutes). Then fire the engine up and let it idle. It may relearn around the problem.
This could just be because your car is used to warm air.
Old Dec 20, 2004 | 03:18 PM
cerfur's Avatar
my sugestion disconect it in cold weather i had a hell of a time last winter
Old Dec 20, 2004 | 03:30 PM
gbwaacha's Avatar
my idle has been dropping to 500 but i got the codes checked last week and all i had was the code for no cat and a idle to high code
Old Dec 20, 2004 | 03:31 PM
streetspeed's Avatar
This s the second winter that I have had my RRM Piggyback and I haven't had any problems. Like others suggested, try resetting it. If that doesn't work, you might want to check something else.
Old Dec 20, 2004 | 05:12 PM
iyi0521's Avatar
Thanx. Ill try resetting the ECU. i had a hell of a time getting this dang thing installed right so ill check my installation again too. Maybe it got kicked loose. I thought the ECU would have figured out the cold weather situation by now tho. The damn thing is running like crap again too. ill reset the damn thing and get back to you.
Old Dec 20, 2004 | 05:22 PM
And since it's 15 degrees, I am once again reminded why I probably won't get a PB. *sniff*
Good luck with yours!
Old Dec 23, 2004 | 05:31 PM
iyi0521's Avatar
Reset ECU. car took forever to learn to operate in cold weather. Idle at startup was near 3K! Gave it two days and everything seems back to normal now. Havent had a CEL yet. ill give it another week yet.
Old Jan 3, 2005 | 03:57 PM
SIMSSEGA's Avatar
i thought that rrm programmed there pb to run in 0 degree weather. I remember reading that in a post somwhere from rock. Ill pm him and find out for you.
Old Jan 20, 2005 | 11:10 AM
livelyjay's Avatar
I worked with Rock for months when the piggy first came out because it was cold as hell here. I got totally frustrated (after 3 months) with the turnover rates of sending and getting it back from them that I gave up. Since then I have gone turbo and I'm having problems with codes with it in cold weather as well. I haven't checked the code I'm getting right now. An O2 simulator might be in my future.
Old Jan 20, 2005 | 11:14 AM
Alchemist's Avatar
These cars are really sensitive to temperature variances across systems. For example: when I wrapped my header it kept the heat too well and the hot air was being sucked into the inake. The ECU thought the air was too hot, compared to the coolant temp, so it gave me a fairly crippling CEL (no eManage, really rich, etc.)
Anybody got a code reader? even if it doesn't tell you why you're getting the code, post the code itself and we'll see if we can't figure it out
SH0F
Mar 1, 2017 01:34 PM
aptok14
11
Oct 26, 2015 05:00 PM
nongtat
26
May 28, 2006 08:24 AM
Go_Lancer_Go
Lancer Engine Tech
15
Mar 17, 2006 06:30 PM
BLiu
19
Jul 27, 2004 11:55 AM
