Spark Plug wires
Old Jan 11, 2005 | 01:52 PM
OZman27's Avatar
Spark Plug wires
What are the best plug wires for my 02 OZ? and where can i get them? thanks.
Old Jan 11, 2005 | 02:46 PM
pgmike's Avatar
i believe the only aftermarket wires that are available are the magnacores, but dont quote me on that. there are many places on the net you can get them, you can doa serach, just dont get them from rrm, bc they will charge you more than most places.
Old Jan 11, 2005 | 02:49 PM
blacklancerr's Avatar
i would say magnacore. i know i've seen some others on here...try doing a search
Old Jan 11, 2005 | 02:56 PM
Blacksheepdj's Avatar
I have NGKs...
You don't notice anything, but it's one of those "why not" modifications...
Old Jan 11, 2005 | 03:13 PM
pgmike's Avatar
oh yeah, contact petey pab, he found some for pretty cheap
Old Jan 11, 2005 | 05:06 PM
03RallyLancer's Avatar
are the ngks 8.5?
Old Jan 11, 2005 | 05:41 PM
Originally Posted by 03RallyLancer
are the ngks 8.5?
No, they're about as thick as stock. But they make all kinds of wonderful claims to be resistor wires and that thickness isn't the key (basically, the subtly accuse Magnacor of making wires that are overly thick and just padded).
From NGK:
NGK Wire Sets
Our Spark Plug Wire Sets are built to meet stringent OEM tolerances for a variety of import vehicles
Superior Firing and Fuel Savings
Outstanding Durability
Consistent Performance
Excellent Noise Suppression
Perfect Fit for Your Car
When a spark plug fires, it creates a great deal of radio frequency interference (RFI). Uncontrolled, this can show up as static in the radio or other electronic devices, or much more seriously, in electronic ignitions, fuel injection, and engine management systems. This interference with EFI and engine management systems can cause "cross talk" between wiring harnesses resulting in poor running, misfiring and decreased performance.
NGK Resistor Spark Plug Wire Sets utilize a construction method known as "variable pitch" wire winding to create resistance to radio frequency interference. The variable pitch winding (loose/tight/loose) provides suppression throughout a very wide range by "scrambling" and breaking up the electrical waves radiated by the firing of the spark plugs.
CONSTRUCTION
A ferrite magnetic layer consisting of a mixture of rubber, plastic and powdered ferrite magnetic materials, offers uniform resistance and unsurpassed conductivity. NGK wires have a lower resistance than conventional carbon core wires (8k ohm/meter vs. 16k ohm/meter). This comparison is important to remember when you consider that many manufacturers recommend wires be replaced when the resistance exceeds 20k ohm/meter. This does not leave much margin for wear when the wire may only meet original standards at the very early stages of its life.
At the center of NGK Resistor Spark Plug Wire Sets is a fiberglass stranded core, made from the same family of materials used in bullet proof vests. This core greatly enhances the overall strength of the wire, providing a super strength backbone on which the various layers of the wire assembly are formed. The core gives protection from damage caused by the pulling strains that wires are often subjected to and that can destroy their performance.
High quality EPDM and Silicone coverings are used to resist high heat, oil and chemical damage for increased durability.
Custom designed terminal boots are always used to provide exact fit (not universal fit like other major wire manufacturers). Each NGK ignition wire is fitted with a positive locking, corrosion resistant nickel plated terminal end for tight fit and maximum resistance to vibration and separation.
NGK Wire Sets are numbered to correspond to cylinder numbers and coil wires are color coded for correct and easy installation.
Old Jan 12, 2005 | 01:17 PM
OZman27's Avatar
thanks guys I will check out both. Do you have the stock number for the NGK's?
Old Jan 12, 2005 | 04:03 PM
GreenPsycho's Avatar
i got my magnecores off ptuning.com. pretty cheap price i reckon
Old Jan 12, 2005 | 04:46 PM
$70 ain't bad. But the NGKs were $20!
Old Jan 13, 2005 | 01:30 PM
OZman27's Avatar
Me being a poor college student, those NGK's are looking nicer.
Old Jan 13, 2005 | 01:33 PM
pumpdog720's Avatar
I have Magnecor wires. You can't tell anything from them, but hopefully they are doing their job and making a better spark! Haha!
Old Jan 13, 2005 | 01:49 PM
Archangelite's Avatar
hey do they NGK's come in blue? any links?
Old Jan 13, 2005 | 03:43 PM
NGKs are blue only.
Old Jan 13, 2005 | 03:48 PM
Alchemist's Avatar
damn DJ- give us the part # already And where'd you get them? This might be a nice dressup/slight performance mod.
