Valve Cover Bolts
Old Jan 21, 2005 | 07:22 PM
yellowlancerOz's Avatar
Valve Cover Bolts
I started to notice oil dripping out from the valve cover. Each bolt was loose so I tighten down. What would cause these bolts to get loose and what is the suggested torque that I should tighten these bolts at?
Old Jan 21, 2005 | 09:46 PM
4g94T's Avatar
30inch-lb for the six bolts
Old Jan 23, 2005 | 09:34 AM
thanks....would u happen to know why they would come lose in the first place?
Old Jan 23, 2005 | 12:23 PM
maxum17ft's Avatar
also does anyone know how much 30 in.-lb is in ft-lb.
Old Jan 23, 2005 | 09:21 PM
03RallyLancer's Avatar
well how many inchs are in a ft? sorry for the smart *** comment. Anyways should be about 2 1/2 ft-lbs... if you know any friends with snap on tools they have really good trq wrenchs in inch-lbs.
Old Jan 24, 2005 | 01:06 PM
livelyjay's Avatar
It might not be the bolts that are the problem. The gasket for the valve cover might be blown. If you have the bolts torqued down to the correct spec as stated above, then the gasket may be the culprit.
Old Jan 29, 2005 | 12:33 PM
well i tighten the bolts and i have no more leaking...hopefully that solved the problem....i got close to 50,000 on the motor i dont see how i can blow a gastket but i think of that as a problem
aamoedo
14
Dec 27, 2016 08:31 AM
$MIVEC$
Jul 21, 2008 08:41 AM
STOCK_EVOLUTION
Mar 15, 2007 09:20 AM
ThEHiTMaN
Dec 25, 2005 09:14 PM
GOKOU
22
Apr 8, 2005 03:44 PM
