Stripped Coil Bolt on Valve Cover
So I over tightened one of my coil bolts on the valve cover last time I changed my plugs. It still threads in, but won't tighten completely though, it's not necessarily loose either. Anyone else done this? And any ideas how difficult it is to retap the valve cover if I took it to a machine shop? There's two other bolts, so it's not a huge deal, but I was also thinking about upgrading to the Spoolinup setup in the future, and unfortunately I stripped the one bolt the COP uses.
Or take the bolt to your local hardware supply and ask them for the next size up, buy the drill and tap to match, and that should fix your issue because you can fit a slightly bigger bolt in the coil hole.
For future reference use your index finger and your thumb to tighten bolts like that, you'll never strip one again..
You can get longer bolts of the same size. THe valve cover Coil Holes are deep. Home Depot carries the same pitch and size thread bolts in various sizes. Had to do this myself for the ******* who stripped all mine out. But a quarter inch longer bolt will work. Use smallest wrench/ratchet to tighten.
Originally Posted by 4b11slayer
Worst comes to worst. Replace valve cover.
If the cylinder affected isnt misfiring. Your good
You're saying there are threads beyond the standard bolt size?
Hell, I found Aftermarket Throttle Body Allen Hex Head Bolts at Home Depot....
Same happened to me.
I had it re-threaded in 5 minutes
And then i bought the STM SS valve cover kit
And THEN i changed those to black TiTanium ones
Re-Thread.. get a new set ! For some Bling !
Lancershop has the TiTanium ones.. color options too.
Bysek
Oct 1, 2013 03:16 PM
