start-up question..
Old Feb 13, 2005 | 01:19 PM
g0damy0uugly's Avatar
start-up question..
hey iono if this is in the right section but... i noticed that everytime i start up my car... it high revs to about almost 1.5-2k rpms.....right as i turn the key for ignition... what does it mean?!....any insight would be helpful im just curious and wondering
Old Feb 13, 2005 | 01:25 PM
maxum17ft's Avatar
thats cold start the motor revving high is normal but only at cold startup
Old Feb 13, 2005 | 01:57 PM
it never used to do that before..... i almost have 40k miles on my car but prolly before 30k it wasnt doin that
Old Feb 13, 2005 | 08:35 PM
evodreamer01's Avatar
my car @ start-up does the same thing as it heats up it goes down to normal idle
Old Feb 13, 2005 | 11:03 PM
HobieKopek's Avatar
Definitely the cold start function. If your block/engine is cold, the atomized fuel will condense into droplets on the cylinder walls more easily. If you didn't know, fuel burns in its gaseous stage (which is why if you ever see a puddle of fuel burning it seems like the flame is slightly above the liquid). The condensation means less atomized fuel is available, therefore creating a lean condition and potentially predetonation/knock/ping or whatever name you know it by. To combat this the ECU does what was already described as a cold start. Essentially it just dumps even more fuel into the mix, not only to compensate for condensation, but also to speed up the process of bringing the engine/coolant to temp. It's nothing abnormal, and your car has probably either 1. been doing it without your noticing (more likely) or 2. not needed to do it before because your coolant temps had not been as low or your knock sensor wasn't picking anything up before recently (less likely).
It's definitely normal though. On an aside, try programming this **** on a standalone sometime. What a pain in the *****.
Old Feb 14, 2005 | 02:01 AM
that clears it up.....thanks alot for explaining that to me
Jdubya555
Lancer Troubleshooting
Mar 30, 2017 08:04 PM
k0lok0yboi
13
Apr 18, 2016 02:08 PM
black_beauty
14
Mar 4, 2010 09:19 AM
spm1024
14
Oct 19, 2005 05:09 PM
