Back firing
Old Feb 13, 2005 | 07:17 PM
josh930's Avatar
Back firing
Inbetween shifts my car back fires at a high rpm. Any suggestions on what it could be?
Old Feb 13, 2005 | 07:19 PM
Iamkar33m's Avatar
List your mods, that'd help alot.
Old Feb 13, 2005 | 07:38 PM
josh930's Avatar
Mods: RPW header, Intake mani, Throttle body, CAI, 2.25 custom exhaust, Piggyback, gasket matched head
Old Feb 13, 2005 | 07:39 PM
josh930's Avatar
My car is also running rich because my cat deteriorated, now whats that?
Old Feb 13, 2005 | 07:43 PM
Dave@Accolade's Avatar
Its acceleration enrichment adjustment in the ECU is too lean.
Old Feb 13, 2005 | 07:45 PM
josh930's Avatar
Could you explain that a little better. Also, how can you fix it? Thanks
Old Feb 13, 2005 | 07:46 PM
digdat's Avatar
2nd cat deteriorated? how'd ya do that? :P
i'm assuming you've got a service engine light on, yes? that could make the car run richer.. which could cause the backfires.
What kinda plugs you run? Whats the gap? What octane of gas do you run?
Old Feb 13, 2005 | 07:48 PM
blitz01's Avatar
It just simply means you are running too rich, so there is unburned gas in your exhaust so its exploding there. Its because your a bit too rich, its no problem. You can leave it like that or take a bit of gas off with your piggyback.
Old Feb 13, 2005 | 07:52 PM
josh930's Avatar
The cel is on, and I figured it was the piggy. I'm going with the greddy emanage to have contol over it. Thanks, and if theres anything more you can think of let me know.
Old Feb 13, 2005 | 08:01 PM
josh930's Avatar
I have the denso iridium plugs with .044 gap, on 93 octane gas
