Toluene
Old Mar 8, 2005 | 08:41 PM
Alchemist's Avatar
I was refering to your intial post, Viciouz... and it seems like a legitimate question. First out of curiousity- why would you look for an octane booster instead of race gas? And I'm assuming that you're affiliated with RRM because you've identified yourself as such to a friend of mine (regarding the CF wing pics that he wanted removed from the RRM site).... so I figured you have greater access to these guys than most of us.
What threads are going downhill? I'm On Topic.....
and since everyone's online: did you try the gas/toluene mix? How'd it work out?
Old Mar 8, 2005 | 09:23 PM
Viciouz's Avatar
I only asked out of curiousity, and I thought it was pretty clear that I work for RRM??? I just wanted to know if this would be a cheap alternative to race gas. And your friend with the cf wing, we didn't mean any harm by that.
Also I tried the toulene/gas mix, and I didn't feel that much of a gain, cept I noticed my egt gauge climbed slower than normal. But not as noticeable as race gas.
Old Mar 8, 2005 | 09:42 PM
Alchemist's Avatar
cool, sounds like a successful test. The mix was approx 94, right? What's the oct of the race gas you've tried?
Just to clarify: I didn't know for certain that you're an employee of RRM and now that the pic is off the site there's no bad blood about that.
Old Mar 8, 2005 | 09:53 PM
Viciouz's Avatar
yah the toulene mix was 94, but the race gass octane was 100
Old Mar 8, 2005 | 11:29 PM
Alchemist's Avatar
Can you try to get the toluene mix closer to the 100 oct? I'm curious if there isn't a noticable difference at similar levels of octane.... but that's cool if you're finished with the experiment, this stuff's expensive.
Old Mar 8, 2005 | 11:38 PM
lookslikeanevo's Avatar
^ ya i would agree with eboy also, you should compare the 2 unless they were gonna be close to the same octane 93 and a 100 is a big gap
Old Mar 9, 2005 | 09:15 AM
Viciouz's Avatar
well the thing is, if you go with more toulene, its dangerous for fuel lines and other things, cuz its PURE, doesn't have any good addititives like gas does... i read a huge thread on it in the Evo forums
Old Mar 9, 2005 | 09:22 AM
4-BNGR's Avatar
You should never exceed 30% ratio of Toluene to Pump Gas (otherwise all your rubber components will get eaten away; gas lines, etc. even o rings)....
Toulene is 114 octane Best Pump is 94 octane
3 gallons of 94 octane and 1 gallon of Toluene make 99 octane fuel (25% of which is Touene).
However, it's a waste of money to make your own gas like this unless 1) you have a FI car 2) you have an NA car with high compression (10:1 or higher) and 3) you are running crazy advanced timing...
On the Evo, Toluene is insane
Old Mar 9, 2005 | 09:24 AM
Viciouz's Avatar
Well my lancer is boosted, and the highest octane i think i can get here is 91, unless i drive far to some gas station to get some... also, what kinda gains do u feel?
Old Mar 9, 2005 | 09:42 AM
zlancer's Avatar
It doesn't harm your engine at all. The only bad thing it does is it can make a brown ash form on your o2 sensors causing the reading to get messed up over time. Keep only a maximun of 60% gas 40% toluene mix since you would be diluting other additives like detergents and anti-static mixtures. So 1 gallon of gas per .4 gallon of toluene maximum and your good to go.
Old Mar 9, 2005 | 10:10 AM
Viciouz's Avatar
i'll stick to the 30% ratio, but its hard to achieve 100 octane, when you only can get like 91 from around here in so cal
AWDrift07
Sep 17, 2005 09:31 AM
Chamama
12
Sep 4, 2005 02:05 PM
tcarretti
Aug 25, 2005 09:40 AM
toluene express
Sep 1, 2004 04:53 AM
theheff
15
Apr 7, 2003 08:20 PM
