CEL light code 0421
Old Jul 10, 2005 | 04:16 PM
oz4g94's Avatar
yes your car should be fine, since you dont have headers just reset the ecu and it could possibly stay off. dont waste your time continually resetting it unless you are getting emissions done.
Old Jul 11, 2005 | 05:03 AM
livelyjay's Avatar
Get an O2 simulator from summit racing, or turn your car around to get the O2 bung behind the second cat. You'll have to extend the wires if you do this, but either way will work.
Old Jul 11, 2005 | 09:51 AM
oz4g94's Avatar
^^^yes that does work. i just got my safc2 and have been messing with it and have tuned and since doing so my light went off . on top of that, you can also get some performance gains if tuned well, i think that it was worth every cent.
Old Jan 3, 2006 | 12:31 PM
Johnny Danger's Avatar
I am throwing code 421 also. I have reset my ecu and I checked it after driving 200 miles, no cel. But the code comes up 421 and mil (malfunction indicator light) is pending. I am in New York, if I reset my ecu I have to drive a certain number of miles or when i take it in for inspection they will know that I reset the computer. Can anyone help me? I guess, what I am looking for is the second o2 sensor. I know where the first o2 sensor is right behind the radiator on the exhaust manifold. Is the second o2 sensor easy to get to? I am newbie so if I am asking something that has all ready been asked... sorry. I have been searching for the right answer.
By the way I drive a 2002 Lancer ES
Last edited by Johnny Danger; Jan 3, 2006 at 12:32 PM. Reason: Mention car make and model
Old Jan 3, 2006 | 12:35 PM
blaze_125's Avatar
If you look under the car and locate the cat converter, you'll see the second o2 sensor attached to it. RRM sells a fix for that.
Old Jan 4, 2006 | 09:00 AM
thanks blaze
I appreciate all that help us newbies, like I said I am a newbie but I am a fast learner.
Many thanks, hope to be up and running legal again real soon!
Old Jan 4, 2006 | 09:04 AM
EarsLikenElf's Avatar
2 18mm atnifoulers is the best fix. THis is what I use. No CEL after 10k miles... no wiring, no resistores, just a little bit of alluminum :-) PM me if you need further info.
- Andy
Old Jan 4, 2006 | 11:17 AM
Zerolancer's Avatar
ok since its the 421 thats is a recal for our car 2002 2003 lancers just bring it into the shop .. i mean mitsubishi and they will reflash your pcm then it should be goood
Old Jan 4, 2006 | 11:53 AM
blaze_125's Avatar
I think you should go back to the first post and start reading.
I have a intercooled turbo lancer pushing 7 psi
That means he doesn't have the factory exhaust manifold. That means the recall doesn't apply to him.
Old Jan 4, 2006 | 01:01 PM
Zerolancer's Avatar
im running 2.5 cat back and the factory warenty still applies
Old Jan 4, 2006 | 01:12 PM
blaze_125's Avatar
You don't get it hein??? The recall you're talking about has to do with the FACTORY exhaust manifold throwing a code. This guy DOES NOT have the FACTORY exhaust manifold. It's not a matter of voided warranty(and in it's case it's obviously not under warranty anymore since he's boosting) it's a matter of fixing the right problem with the right solution.
P0421 can occur for different reasons
1. Mitsu lack of pickyness when they first programmed the Ecu
2. No cat in the exhaust manifold
The recall applies to situation #1 only.
Right now you're telling this guy to go to a Mitsu dealer to get his ecu re-flashed so he doesn't mess up his first cat converter. Well you know what? He doesn't have the first cat anymore.
Old Jul 4, 2006 | 08:46 PM
turboslik's Avatar
Originally Posted by Blacksheepdj
Since you dropped a few thousand on a turbo that is easy to destroy, YES, it would be wise to let the car warm up for a couple minutes before driving.
Heck, just the investment in a car would necessitate letting it warm up in my eyes. I paid $14000 for my car (more after interest), and I'm not going to harm it because I'm impatient.
lol reminds me of that time i started up my old '79 350ci camaro and just stomped...after a short while it sounded like a baseball bat was hitting my block (aka slung rod grinded crank shaft.../cry)
herbdean
Jan 3, 2015 04:28 PM
Swankzer
Lancer Troubleshooting
40
Apr 6, 2010 05:52 PM
bluelancer20028
Sep 24, 2009 09:45 PM
sykou
Oct 24, 2007 07:47 AM
RumbleCam
May 2, 2005 10:12 PM
