Exhaust
Old May 6, 2005 | 11:27 PM
Matt000's Avatar
Exhaust
Not sure if this is the right forum to post this question in, and yes I already did a search but I'm looking for an aftermarket exhaust with the following specifications:
1) doesn't melt/damage rear bumper
2) not too expensive
Old May 6, 2005 | 11:28 PM
AznFlip's Avatar
eBay, i got mine around 50 and it's grreat
Old May 6, 2005 | 11:45 PM
lookslikeanevo's Avatar
answer is none.....
you get what you pay for.... you wanna go cheap? then go cheap! other than that there are enough threads on exhuast to know which one fits yout needs
Old May 7, 2005 | 12:02 AM
EvoGuy04's Avatar
If your going to spend money you might as well get a what you want, like they said "you get what you pay for" rules to live by.
Old May 7, 2005 | 07:22 AM
wiretap's Avatar
catback? ---> magnaflow.
edit: I assume when you say exhaust, you mean a full exhaust, not a muffler...
Old May 7, 2005 | 08:44 AM
SLVROZ_03's Avatar
Check here for the cheapest, new Magnaflow catback I've seen : ( http://cgi.ebay.com/ebaymotors/ws/eB...RK%3AMEWA%3AIT )
Old May 7, 2005 | 09:07 AM
BensLancer's Avatar
Thumbs up You best bet!!!
Performance Peddler Man!!! Got mine in 3 days! Free Shipping!!!! Unless you got enough money for that DC Sports Dual Canister Catback System, This is the best one you will find!
MagnaFlow Catback Exhaust 15805
Good Luck.
Ben
Old May 7, 2005 | 09:47 AM
wiretap's Avatar
I got my magnaflow catback for around 310 dollars. I ordered it from a custom tuning shop in my area that is now shut down. They should be around 310 bux on ebay once and a while, just keep your eyes peeled..
Old May 7, 2005 | 09:52 AM
Grnd0Lancer's Avatar
magnaflow exhaust
You can go to a muffler shop get 2 1/2 inch pipe bent the way you want it for your Lancer and that comes out to about 90-100 bucks and then put a magnaflow muffler to it. That's the best way to do a magnaflow catback. Almost half the price for the exact same thing you would get if you bought it from magnaflow.
Old May 7, 2005 | 03:51 PM
Supa tek's Avatar
You'll only get about 2-5hp with anyone you buy.
Old May 7, 2005 | 03:53 PM
firebolt's Avatar
my oz had a melting problem. nothing a heat sheild couldn't fix. if u want cheap make it urself. u can get it done for around $125.
Old May 7, 2005 | 09:13 PM
redozrally's Avatar
get one with the tip double walled, that should prevent the bumper from melting...
+ magnaflow is pretty cheap around 100 bucks... I just bought the universal one and had a shop weld it on...
chop old pipe weld muffler with some extension pipe...
Old May 8, 2005 | 10:28 AM
chrls000171's Avatar
you should get a FULL exhaust system. i.e. magnaflow with a catback. a muffler doesn't do anything but make loud noise...and some people call that rice
Old May 8, 2005 | 11:04 PM
UNeK02's Avatar
you know i never understood the point of just putting a muffler on if you arent going to do the whole thing but i think custom is the way to go in the long run its cheaper and you can get it made to your specs
Old May 9, 2005 | 06:36 AM
redozrally's Avatar
well 1 its a lot cheaper than a full cat back system... so if you can't afford one at the moment get the muffler now and do the mid pipe later... aftermarket does flow better than some stock muffler and sounds better...
