low idle. due to MAS?
Old May 26, 2005 | 08:24 AM
bettorer's Avatar
my idle is running really low like 600. when i was taking off the mas i put a tiny little knic in it. could this be causing my problem. if so how expensive is this to repair . is it worth repairing
Old May 26, 2005 | 10:42 AM
oz4g94's Avatar
did you disconnect the battery? if you did then you reset the ecu, just drive it for a little while and it should be fine.
Old May 26, 2005 | 03:40 PM
bettorer's Avatar
yea i disconnected it. i've driven it like a week now and its still not changing.
Old May 26, 2005 | 03:48 PM
Matthew333's Avatar
try again, disconnect-leave for @ 1 hr, reconnect- this is a lot cheaper than a new mass air---
Old May 26, 2005 | 03:49 PM
bettorer's Avatar
k thanks .. i will try that.
Old May 26, 2005 | 06:53 PM
oz4g94's Avatar
if that doesnt work, then you might have to get a new mas. they are pretty pricey too. from a dealership they'll run a couple hundred $, but if your look at a junkyard for a fair one, you could probably get it for about $20-30. hopefully you dont need a new one though. good luck
Old May 26, 2005 | 08:09 PM
KillahB's Avatar
When your car is running, tap on the top of the MAS. While this is not a definitive test, if the car dies, you may have a bad MAS.
Old May 26, 2005 | 08:20 PM
bettorer's Avatar
well i did the battery disconnect for a little over an hour. It started off running nice at a little over 1000 then i let it run for about 20 min on idle and when i came back to the car the bastard was back at 600-700. Is that normal after running for a while or should it stay up around 1000. if it is my mas could this cause serious damage if it isnt' fixed?
will a 4g63 MAS work? i found one on ebay for like 7 bucks
Old May 26, 2005 | 08:21 PM
KillahB's Avatar
Normal idle is 750 +/- 50 RPMs tho. Try to adjust the BISS screw if all else fails.
Old May 26, 2005 | 08:25 PM
bettorer's Avatar
what is the BISS screw .. the mas i found on ebay is for a 97-99 eclipse. and the rpm is more like 600 closer 650 max i would say after taking a second look,
Old May 26, 2005 | 08:39 PM
Blacksheepdj's Avatar
After a few days of watching the digital readout on my SAFC, I can say that normal idle seems to be 700 for me. But every car is a little different.
Old May 26, 2005 | 08:41 PM
bettorer's Avatar
when im idling at a stop light or something. it will sound like its almost going to stahl out though. alot of times i keep my foot on the gas a little to get the rpms up to about 1ooo.
Old May 26, 2005 | 08:47 PM
Matthew333's Avatar
idle
what happens when you turn the a/c on? you may have issues with the iacv (idle air control valve)
Maybe do what AirQuez said - there's a screw on your TB that controls air flow. Maybe have the dealership check it?
Old May 26, 2005 | 08:49 PM
Matthew333's Avatar
safc?
