Mirage Header and Downpipe
Old Jun 3, 2005 | 08:51 AM
GreenPsycho's Avatar
Originally Posted by Jotun
No basically you just want to go to a muffler shop for 40 bucks and get a O2 Bung welded into the header and have them cover the old one. I have a Mirage header I did it and it works great. Secondly You dont nesasarilly want to change the length of the O2 sensor wire as that will change the resistance of the wire which in turn will cause your "Check engine" lite on. So DONT CUT THAT WIRE trust me....
whaaat? i realize drastically lengthening a wire could possibly increase resistance, but we are talking inches, perhaps a foot at the most and soldering the connections. what would be the delta resistance: it would be so little it would hardly register as any change at all even on a super precise ohm meter
yes, don't lenghten the o2 sensor wire by like 200' feet and use butt connectors, but short of that, i think your gravy..............unless any EE's can prove me wrong
Old Jun 3, 2005 | 12:37 PM
oz4g94's Avatar
yes as greenpsycho said, your probably best off lengthing the wire if you do get the mirage header/dp, it will cost next to nothing as opposed to the $40-60 it would getting a new bung put in. if im not mistaken, the wire will have to be lengthened about 2ft, the bung is at the end of the dp, just before the flange to connect the cat.
Old Jun 3, 2005 | 12:44 PM
hybridevo's Avatar
yeah but im scared i might break it though? well im still thinking of getting the mirage header/dp or just get the rpw race headers but we'll see whats happens
Old Jun 3, 2005 | 12:50 PM
oz4g94's Avatar
the rpw race headers are definitely not worth what you pay for them, i very highly doubt you will get more gains out of their headers than anyone elses. if you plan to buy some that are specifically for the lancer, do yourself a favor, save some money and either get the rrm (does not come with dp), or the kamikaze (which do come with a dp). then put the money you saved from buying one of these headers toward a piggyback ecu.
Old Jun 3, 2005 | 12:54 PM
hybridevo's Avatar
thats a good point though but i've read here in the forums that the rrm & kamikaze all cause the cel to come on is this true? how much is a mirage header/dp anyways?
Old Jun 3, 2005 | 12:59 PM
oz4g94's Avatar
all aftermarket headers made for the lancer will cause cel. your stock manifold has the first cat in it, by removing that, the second o2 sensor reads the exhaust as having a heat up prob, so you would either have to get a mil eliminator for the second o2 sensor or you could do the anti fouler trick.
Old Jun 3, 2005 | 01:01 PM
hybridevo's Avatar
do you know any vendors who sell mirage headers?
Old Jun 3, 2005 | 01:09 PM
oz4g94's Avatar
there was some person selling them on ebay for a while, but she had such bad feedback you wouldnt want to buy from her, im not sure where else you can buy them from. those mirage headers will also cause cel. you can get the kamikaze from ptuning.com for 259 shipped, for the black temp coated.
Old Jun 3, 2005 | 01:12 PM
hybridevo's Avatar
yah i might go with the kamikaze then
Old Jun 3, 2005 | 01:16 PM
oz4g94's Avatar
thats what i have, i think they work fine, you dont get much gains from them, but get a piggyback ecu, and you can get the most out of them.
Old Jun 3, 2005 | 01:22 PM
AAAAHHHHH, dude, just sssshhhh it, you are spreading SOOOO much bad/misinformation
first off, rpws header do offer increased performance, not in HP, but in torque because of the design by itself. its just a fact. and when you go super (like i am) the runner lenght and design really makes a difference, in fact ripp told me they've measure about 9% change in torque on our size engines, which could mean the difference of 20 lb/ft when your pushing stage2.
second, aftermarket headers do not cause the cel, is the removal of the first catalytic converter in the stock extractors that does. if you are smart about it, there are several cheap/freey ways to counter this, ergo, any header could or could not cause cel, its just up to the user. but because rpw places its 02 sensor bung on a single tube instead of on the collector like kamikaze and rrm, most people found in the stock configuration, it will not cause cel
kamikaze and rrm headers are very VERY much alike. but kamikaze comes with dp and is cheaper
Old Jun 3, 2005 | 01:35 PM
oz4g94's Avatar
What misinformation? all the info given is opinionated, you have yours i have mine.
that little bit of extra tq that the rpws will give will not make much of a difference, and in MY OPINION are not worth $500+.
i doubt that he will run a supercharger, ask him. most people that would spend money on forced induction will not spend on supercharger, because you have that really queer sounding whine from the belt.
i told him that removing the first cat will cause the cel (it is because the aftermarket headers do not have a cat in them), read the posts thoroughly before saying anything.
Old Jun 3, 2005 | 04:03 PM
N1te's Avatar
https://www.evolutionm.net/forums/sh...ghlight=mirage
my review of the mirage header just might help
Old Jun 3, 2005 | 04:32 PM
Blacksheepdj's Avatar
oz4g94 - he's right. A lot of stuff you said is just plain wrong.
RPW headers - the best available. Completely worth the money. They have solid design. RRM and Kamikaze are both shorty headers. While they're nice, they aren't the best.
CEL - some headers don't cause it. Even RRM and Kamikaze. It differs from car to car. And there are other tricks to bypass it.
etc etc.
Old Jun 3, 2005 | 04:44 PM
HobieKopek's Avatar
I think you're on the short side of the info here, oz4g94. If anyone has an independent dyno claim that can put the kamikaze header near the 17whp gain from RPW's I'd be seriously impressed. RPW has the design and racing experience, R&D and dyno proven results to back their product. Is Kamikaze a good buy if you want to save money? Sure. But if you want real gains I can only think of RPW as the best buy.
