Mirage Header and Downpipe
Old May 27, 2005 | 07:55 AM
rallylanceroz03's Avatar
Will the Mirage Header and downpipe fit on a 2003 lancer oz. i want to cut a few corners and save money and to get an aftermarket header and downpipe for a mirage is much more reasonable priced then one for our cars. if anyone has any ideas please let me know thanks.
Old May 27, 2005 | 08:37 AM
blaze_125's Avatar
it will but it will be a bit short.... If I'm not mistaken, you can just stack a few gaskets between the header and the dp.
Gunshin's Avatar
The downpipe would probably give you trouble since the 4G94 is taller than the 4G93.
EDIT: I snooze, I lose.
Old May 27, 2005 | 10:14 AM
Blacksheepdj's Avatar
Incidentally, want to buy a Mirage header cheap? I have an extra.
You could probably just get/make a spacer for the header/DP connection to make it work out.
Old May 27, 2005 | 09:54 PM
hybridevo's Avatar
but will the header fit though?
Old May 27, 2005 | 10:12 PM
how many gaskets would i need to get that to work then or is there any other routes to take
Old May 28, 2005 | 06:50 AM
SIMSSEGA's Avatar
i havent done i but i read that about 3 would do the trick.
Old May 28, 2005 | 01:25 PM
Well, let me know.
hybridevo - never tried. Just offered it up.
Old May 28, 2005 | 03:51 PM
oz4g94's Avatar
the mirage header/dp will fit a lancer, but there is an 02 sensor bung in the dp not the header.
Old May 28, 2005 | 08:47 PM
hybridevo's Avatar
so we need to get like a longer o2 sensor? a longer wire or something?
Old May 29, 2005 | 03:14 AM
Jotun's Avatar
No basically you just want to go to a muffler shop for 40 bucks and get a O2 Bung welded into the header and have them cover the old one. I have a Mirage header I did it and it works great. Secondly You dont nesasarilly want to change the length of the O2 sensor wire as that will change the resistance of the wire which in turn will cause your "Check engine" lite on. So DONT CUT THAT WIRE trust me....
Old May 29, 2005 | 11:33 AM
oz4g94's Avatar
you should just save an extra however much money and buy the kamikaze black temp coated header/dp. you can get it from ptuning.com for 259 shipped, i think thats what i paid. good luck on your decision.
Old May 31, 2005 | 06:54 AM
My O2 sensor works fine after being lengthened...
Old Jun 2, 2005 | 07:03 PM
Mitsiman's Avatar
It depends upon the brand header nad how it is setup. the 4G94 block is taller and the sump pan slightly different. Normally most headers will foul on either the engine block or sump pan as well as teh flex pipe fitment will definitly not bolt up as there is a funny bend in the stock setup which has to be replicated.
Old Jun 3, 2005 | 08:43 AM
oz4g94's Avatar
they will fit, either lengthen the o2 sensor or have a bung welded higher so the o2 sensor will reach, and close up the bung on the dp.
