A/F ratio for n00bs
Old Jun 21, 2005 | 10:23 AM
  #106
gregivq's Avatar
^ I'm confused??
12.7:1? I'm at 10.5:1 and I'm not planning on boosting.
I'm sorry if I am confusing anyone.
^Ok, 10.5:1 plus Fi would leave me at 12.7:1?
Old Jun 21, 2005 | 10:43 AM
  #107
livelyjay's Avatar
Originally Posted by engineerboy
ok real quick before my boss starts looking in on me:
I meant add'l injector map. Sorry. It works along the same lines as the main map, but you change the %age that the injectors work.
I'm going to use the VTEC controled for an O2 sensor clamp- it'll intercept the O2 sensor signal at my chosen RPM and relay to the ECU that everything is fine and not to worry.... I hope.
Do you mean the first O2, or the second O2?
Originally Posted by gregivq
^ I'm confused??
No, since you are NA, you want to be more lean at a 12.7:1 ratio. For FI like me, a richer A/F ratio is desired just in case of boost spikes and such, so a 11.5:1 would be a good target. So, you will want to remove fuel using SAFC or Emanage and I will want to add fuel.
Old Jun 21, 2005 | 11:04 AM
  #108
gregivq's Avatar
My bad, I got it confused with compression ratio .....
Old Jun 21, 2005 | 12:54 PM
  #109
Alchemist's Avatar
1st O2. It's the controller. The 2nd O2 is just a check that the primary cat is indeed doing it's job.
Old Jun 22, 2005 | 02:36 AM
  #110
Slovak's Avatar
OK, after reading this thread and similar others, from what I understand one can only expect about 5hp, not even whp total from any on the management units? And it is also usually better to pay someone to tune them? All that money spent for only 5hp What about torque? How much torque can be expected?
I ask because I was considering a SAFC-2.
Old Jun 22, 2005 | 02:39 AM
  #111
HobieKopek's Avatar
See my last post on the subject. If you're thinking of each engine management system as additional HP, you're missing the point. You're essentially asking how much HP to expect from a tune.
Old Jun 22, 2005 | 02:48 AM
  #112
Slovak's Avatar
I did read it, so how much hp from a tune can be expected? Only about 5hp? That's an awfully expensive tune for 5hp or less IMO. If there are no gains from such an expensive tune job, then what's the point? The only gains most folks want from a "tune job" are hp and torque. The whole purpose of fine tuning our imports is to squeeze every last bit out of the engine as possible.
Old Jun 22, 2005 | 04:08 AM
  #113
livelyjay's Avatar
I can speak for the FI side of things, you're paying that money so you can increase boost and not go boom. As for NA, if you tuned it right it will yield the same results as the RRM piggyback, which IIRC is 10%.
Old Jun 22, 2005 | 08:51 AM
  #114
rhyzin's Avatar
there's also the whole "power under the curve" thing. if you compare the rrm tune dyno to a baseline dyno, there's more power being made in the midrange than stock as well as an increase in peak hp. saying you gained 5whp doesn't really mean much until you look at the full dyno.
Old Jun 22, 2005 | 10:49 AM
  #115
Blacksheepdj's Avatar
You shouldn't be thinking of a tune in terms of gaining HP.
That's what they're saying.
You should think of it in terms of quality HP. Rather than gaining 5hp at peak (because who drives at 6k rpm that often?), you should think about the dyno curve - if the curve becomes bigger, then you have more power. Even if the peak HP stays the same, you will have TUNED for more power.
Old Jun 22, 2005 | 12:54 PM
  #116
HobieKopek's Avatar
Thanks, Doug. I can stop banging my head on my desk now.
Old Jun 22, 2005 | 12:58 PM
  #117
livelyjay's Avatar
Yay clarity. Too bad the people at Auterra aren't thinking clearly. I ordered their product for Windows, everything on the box and in the box says Windows, yet the CD packaged with it says it's for Plam OS. Grrrrrrrrrrrr.
Time to go dyno (they better not f*** me over today like they did yesterday) so I can find my hp, tq, and A/F ratio.
Old Nov 16, 2005 | 12:11 PM
  #118
gregivq's Avatar
How does cold weather affect Air Fuel ratio and fuel burning in the combustion chamber?
The colder the air, the denser it is, right? So, can you substract couple of % from the map during the winter?
Old Nov 16, 2005 | 12:56 PM
  #119
rhyzin's Avatar
the Long Term Fuel Trim is supposed to take care of that.
Old Nov 16, 2005 | 12:59 PM
  #120
03RallyLancer's Avatar
^^ i would just take a peak at your wideband every 20 degrees or so and make sure the LRFT IS taking care of it. Which is what i plan on doing...
