View Poll Results: RRM PIGGYBACK ECU
RRM PIGGYBACK ECU
50.00%
RRM PIGGYBACK ECU
25.00%
RRM PIGGYBACK ECU
75.00%
RRM PIGGYBACK ECU
50.00%
Multiple Choice Poll. Voters: 4. You may not vote on this poll
RRM Piggyback ECU Does it Really Help
Old Jun 7, 2005 | 12:45 AM
mightymitsuu's Avatar
Question RRM Piggyback ECU Does it Really Help
My question is when it's installed can you feel the difference and around what HP figure do you think it gives you; is it woth the $449? Maybe any dyno sheets? And second, how crucial is it to always run 91 octane when its installed? Thanks.
EDITED for grammar for my own sanity. -Blacksheepdj
Old Jun 7, 2005 | 12:54 AM
Smoku's Avatar
it's worth it.. do some search.. there is a whole thread about it...
Old Jun 7, 2005 | 01:14 AM
Handmemyarms's Avatar
yeah, i didnt think it would do much but it totally made the feel of my car more agressive, gas is more expensive but i dont feel at all bad about it when im paying 25 bucks for a full tank and my mom is paying 80 a tank to fill up her suburban
Old Jun 7, 2005 | 05:54 AM
livelyjay's Avatar
Thank god you posted a poll for this topic.
Piggy is worth it if you can get a good deal on them (used). $450 is a big chunk of change and it's useless if you want to go Stage 0 or Stage 1 turbo, but the advantage is it's just install and forget about it. Plus you MUST run higher octane fuel with it because the piggy advances timing and you need the higher octane to prevent knock.
If you'd like to learn more about your car and get some experience tuning, going with a wideband O2 sensor (PLX, Zeitronix, AEM, Innovative) and a Greddy Emanage system is a better way to go. Sure what I suggested will run you around $700 total. The difference is a WBO2 and Emanage are universal and can be used on any import. That makes them easier to resell if you ever get rid of your car. It will also give you more flexibility as far as tuning for your future/current mods. The drawback is it isn't just install and go, you need to tweak them a lot to get the full benefits. Also, you don't need to run higher octane with this setup (unless you advance timing).
Old Jun 7, 2005 | 06:26 AM
Blacksheepdj's Avatar
search
Hiboost
14
Aug 22, 2015 09:11 AM
Carver
Jul 19, 2015 09:59 AM
SQ2Evo
12
Feb 16, 2013 08:43 AM
NoTn41
10
Sep 19, 2007 11:43 PM
J8dailo
Nov 15, 2004 07:49 PM
