exhaust leak
Old Feb 18, 2003 | 08:43 PM
ratboy128's Avatar
exhaust leak
i just installed my kamakazi header and i used all new gaskets, the header is great, little less low end power but seems like more hp 3500rpm+ and it starts to rev really fast when it hits 3.5k, also it sounds great. i just wanted to know how i could check to see if it was leaking any exhaust gas from the gaskets, i don't want to kill myself with carbon monoxide while i'm driving.
thanks
Old Feb 18, 2003 | 09:22 PM
pjal84's Avatar
If the idle is holding fine and and there's no strange lag and copious amounts of fumes coming out of your bay, you're fine. Can always try to listen for a hiss or a rattle shake if something isn't bolt well enough together.
Old Feb 18, 2003 | 10:08 PM
Boeturbolancer's Avatar
You could also do the cold check... when engine is cold put ring of oil/water/some easily moved substance that adheares a bit-then start her up. If there is a leak you will see to substance gone. Chances are that if she doesn't leak cold she won't leak hot.
Evo23IG
Oct 21, 2012 03:52 PM
04mralliart
04-06 Lancer Ralliart How To Requests / Questions / Tips
13
Sep 26, 2012 05:10 AM
Ghostdriver22
May 10, 2012 11:23 AM
EyeDreamt
Lancer Engine Tech
Oct 30, 2010 07:06 AM
Carloverx
11
May 22, 2009 09:16 AM
