Different management units / different use and benefits
Old Jul 21, 2005 | 09:25 AM
  #31
oz4g94's Avatar
Originally Posted by WADADLIG_OZ
I think the AFC's only do 20%
safc2 can also be tuned +-50%. i am only running mine -1% from 1600-3400 under low throttle, i really need to get it tuned and dyno'd or get wideband.
Old Jul 21, 2005 | 05:15 PM
  #32
03RallyLancer's Avatar
for that to work i believe you will ned a wideband so you need to add another 300 or so onto that price
Old Jul 21, 2005 | 08:16 PM
  #33
oz4g94's Avatar
yeah i would love to get wideband, thats my next mod that im going to do. i have been reading about it, and learning more. would yall say the aem uego is the best or should i go innovative motorsports? 03RallyLancer, which do you have or which are you getting and let me know how you like it once installed.
Old Jul 21, 2005 | 10:45 PM
  #34
i havent really narrowed it down yet... i may go with what eboy got the zeitronix(more then likely)... very good price and can log... my main concern is that it log and that it is accurate. I was gonna get the PLX but it cant log w/o an xtra 100-200$. I feel the others are too expensive when you are getting the same thing. Ask andrew(hobie) about the aem i believe he has it.
Old Jul 22, 2005 | 05:17 AM
  #35
HobieKopek's Avatar
I do have the AEM UEGO and the EMS. I'll be happy to field any questions that I'm capable of answering.
Old Jul 22, 2005 | 11:16 AM
  #36
silkymp's Avatar
How do you like the uego? and do you think you would have chose it or recommend it if you dodn't have the ems?
Old Jul 23, 2005 | 07:14 PM
  #37
KillahB's Avatar
Originally Posted by HobieKopek
Yeah, that's basically what your ECU does in closed loop operation anyway. I'm curious why the E-manage would try to take over that function when it's something that the ECU is already capable of on its own. In theory all the E-manage should need to do is intercept the O2 sensor(s) signal(s) and tell the ECU that the reading is off by the difference between stoich and actual AFR. I dunno if I worded that correctly as I'm a wee bit out of it, but I think the principle's pretty clear.
Makes me go hmmm... as well. Seems redundant to me.
Old Jul 23, 2005 | 08:15 PM
  #38
Alchemist's Avatar
yes, but now the eM Ultimate does that in open loop when the ECU isn't in control. The same reason we even use these damned things in the first place: high throttle applications. So you dial in 11:1, 12.5:1, 13:1, whatever, and the eM Ult keeps it pretty darn close.
Old Jul 24, 2005 | 10:40 AM
  #39
HobieKopek's Avatar
I like it just fine. I have the first run, but if I were to buy one now I'd get the guage style controller just so that I didn't have to either buy a gauge or monitor AFR solely through my laptop. So yes, I would and DO recommend the UEGO as a fast and accurate solution for wideband AFR monitoring. Considering I'm one of maybe 3 people with I know of who run the EMS on a Lancer it's pretty safe to say that most of my recommendations are for people without the EMS.
Old Jul 24, 2005 | 10:41 AM
  #40
HobieKopek's Avatar
That makes far more sense than the first explanation.
Old Jul 24, 2005 | 02:04 PM
  #41
krimson_binome's Avatar
I have an AEM UEGO with the gauge style and it matches the air pump style O2 gauge they have at the dyno shop I go to. So it seems pretty accurate to me. Also I know at the dyno shop I go to it costs $125 /hr for dyno tuning, so I think it is well worth the extra money for the wideband. Have any of you guys heard of problems with burning the ignition coils when you install the ignition harness on the e-manage? I guess the EVO guys have had some problems with that and I was wondering if we would have the same.
Old Jul 24, 2005 | 03:55 PM
  #42
Alchemist's Avatar
coil burn was "fixed" in firmware update 1.29 or 1.36 No one has said what the problem was, but no one is burning coils with the newest firmware, either.
Old Jul 28, 2005 | 09:12 AM
  #43
gregivq's Avatar
New Greddy Emanage Ultimate edition
I am looking to buy some kind of a piggyback to adjust the fuel maps and ignition timing (SAFC2 goes bye bye).
Regular Emanage with support tool and ignition harness should run close to $450.00
Why not just get the newest edition, Ultimate Emanage.
It comes with :
NEW FEATURES INCLUDE
  • USB Port - improved communications & better real-time data and monitoring
  • Toggle Switch - switch between maps
  • Serial port - monitor and data logging
  • Switch port - Data log & Ign. Cut activation
  • Option 1 & 2 - Connectors for sensors
  • Warning Setting
  • A/T Shift Compensation
  • Channel Change
  • Rev limiter cut
  • Acceleration injection Map
  • Individual cylinder fuel & ignition adjustment maps
  • Speed correction map
  • Coolant temperature correction map
  • Air intake temperature map
  • A/F target value map
  • Ignition adjustment map
  • Acceleration ignition map
  • Nissan Valve control map
  • Analog output map
  • Auxilary output map
  • Idle stabilization map
Additional Features
  • RPM signal recognition
  • Fouled plug feature
  • Data logging
  • Text file save feature
  • Knock monitor (future feature)
  • Ignition timing display (future feature)
http://cgi.ebay.com/ebaymotors/GREDD...ayphotohosting
$430.00
Which one will be the best for a Lancer?
Boeturbolancer said the first edition of the Emanage had many issues and problems that had to be fixed when it got realesed.
What do you think?
Old Jul 28, 2005 | 09:24 AM
  #44
maxum17ft's Avatar
im in this same exact predicament. i have been told by 3 local shops that the new emanage will be harder to tune, simply because its new, so i dont know what to get. at the moment im leaning towards the safc-2, simply because its sooo easy to tune, but i now have wideband so anything could be tuned with time, im lost.
the new emanage is definatly best though, just maybe not for me or u.
Old Jul 28, 2005 | 10:33 AM
  #45
oz4g94's Avatar
i dont know too much about the emanage, except that there is more that you can tune than the safc. i have the safc2 and it is very easy to tune, and since you are wideband, it would be much easier to tune. i think you should just get whatever you want, personally i like the safc a lot, but im not too sure about the emanage because i never even considered it.
