evo8 or secong gen eclipse motor possible swap for an 03 oz??
Old Jul 3, 2005 | 04:11 PM
KillahB's Avatar
User CP FAQ Help Desk Members List Calendar New Posts SEARCH Quick Links Log Out
It can be done with Evo 4+ but not Eclipse.
Old Jul 3, 2005 | 06:01 PM
gorilla unit 33's Avatar
Originally Posted by BeyondRealityOZ
I have an a/t (tryin to switch to m/t wit eng swap) 2003 lancer oz....i cant get rid of it for awhile, but does ne1 kno if an evo8 with fwd tranny wud work (jus a thought more of last option)....or a second gen eclipse motor would work as well?....or ne other motors that wud work?
Thanks
ok as an expeirenced person in this feild i will just give you a price guide line (avereage) and most of the parts you will need in order to do the evo swapp. I my self am going along the lines of doing it without being noticed hear on the boards so that when im done (if ever completed) i can surprise every one just as i did with my flare body .......
EVO MOTOR (does not include trans) = $4k-$8 k depending on condition, milage and all the other good stuff
3rd Gen. Eclipse Trans- prices vary depending on how and where you find it
stage 10 shift kit (for Automatics & for durability also)- $1200
Wiring Harness and re routing - arround 800
custom built IC & intake pipes - once again peding on where u find some one that will do it, may i add price also equals quality (lower probably = ****ier)
custom exhuast and downpipe=Same as above^
motor mounts and trans mounts= some where arround 500-700
++++NOT TO MENTION YOU WILL PROBABLY NEED UPGRADED AXLES ++++
ALSO WITH THE PUNCH OF THE PEDAL YOU WILL NEED WAY BETTER GRIP THEN THOSE STOCK DUNLOPS OR THOSE KUHMO'S THAT CAME WITH YOUR WHEEL AND TIRE PACKAGE (possibility for slicks even)
you gotta remember the evo motor was built to be put in a 3600lbs car or higher and have 4wd not a 2600lb car with front wheel drive
theres plenty more i could probably add to this list and cost but im not fully thinkin right now i just thought id give you a reasonable outlook at prices and what you will need.
also i would add that i did a A/T to M/T swapp in a civic let me tell you THAT IS COMPLETE HELL he constantly had problems and for you looking into gettin that done at a shop id say you would spend atleast 2 grand on just that plus buying the new interior peices.
so over all with the evo swap and mt swapp your looking at arround 15k+ if u get it done at a shop
good luck..... ill keep u updated if i find anything more
Old Jul 3, 2005 | 06:06 PM
BeyondRealityOZ's Avatar
ok then lets say forget i said nething bout evo or eclipse swap.....is there ne motor than swap into the lancer with least amount of trouble or trouble that can b solved.....the price to swap it is priceless i have 2 buddies who r highly into this one who a dsm pro and another whos civic teg genius....so not worry bout prices all i wanna do is convert auto to manual and swap engines...those r the roads im tryin to go down...
