Blown Engine....Thinking about a Swap
Old Jul 26, 2005 | 11:49 AM
  #31
N1te's Avatar
Hey Paul.. what day are we getting started on this? thursday or friday?
Old Jul 26, 2005 | 12:20 PM
  #32
livelyjay's Avatar
It's too bad I'm so fricken busy, otherwise I would help you out. I already have every weekend booked through the end of August
Good luck with the install.
Old Jul 26, 2005 | 01:55 PM
  #33
Jotun's Avatar
Prolly Thursday afternoon I would say. I can take out the old pistons and press the new ones in. While you start dismantling your engine... and we should get a decent amount of it done by Saturday Morning assuming that all goes well. You may even have a car by Sunday.
Old Jul 27, 2005 | 06:31 PM
  #34
peelslancer's Avatar
Originally Posted by Lancerlover
I think your main problem was using 93 octane on stock pistons and rods. Too high octane for internals that are not designed for high compression or high octane of fuel will lead to breaking down of rods and pistons. Anyone agree?...cause if this is not the cause, im scared for my OZ, i only have 14k miles, but beat the **** out of the car. BTW, i have the 7 year 100k mile warranty that came with the car in 2003. I say to stick with a regular lancer 2.0 motor and rebuild with strong pistons and rods, keep stock tranny, and spend extra cash that you were to spend on ralliart to buy a Stage 2 Turbo from RRM.
wait...so 93 is not good for my engine??cuz i ALWAYS put in 93(well...eveer sence i moved to GA..in cali i used 91)
Old Jul 27, 2005 | 06:35 PM
  #35
Shingen's Avatar
Why would 93 octane be good for a car that's was designed to run on 87? It's not helping your engine. In fact it's most likely not burning all of the way. Do a search on gas milage and read up on it. I've said it about fifteen times now, but once agian higher octane does not do anything for our cars but cause eventual problems unless you are tuned for higher octane with a piggyback or a ECU swap. Let's keep this thread clean, run a search and you will find more than enough info on this subject.
Fox
Old Jul 27, 2005 | 07:00 PM
  #36
dang...i did not know that....wen i put in high octane...my car feels like its running better...but i guess i could search....
Old Jul 27, 2005 | 08:25 PM
  #37
Jotun's Avatar
Exclamation
Ok I respect Shingen with every once I have to give the man but that is one of the most absurd things I have heard on these boards. Running a high octane fuel is good for your engine it burns cleaner and I would argue against your claim that it does serious harm to your engine. It has been documented and proven that your vehicle runs much more efficiently and much more power is produced with high octane fuel.
But any ways this is --------------- sorry.
Install of the pistons begins tommorow and also we will probably pull the engine as well so we will keep all posted as to the progresss.....
Old Jul 27, 2005 | 08:43 PM
  #38
N1te's Avatar
paul; bring a camera
Old Jul 27, 2005 | 10:26 PM
  #39
Shingen's Avatar
Paul, I read up on it. I might not know about lots cause using dial up but the ECU on our cars are set to use 87 octane. Seriously though this topic has been majorly discussed. I will look up the threads that pertain to this and send them to you personally so you can read all about it.
Fox
Old Jul 28, 2005 | 03:18 AM
  #40
GreenPsycho's Avatar
i'm with fox on this one, the only thing that happens when a stock lancer uses 93 octane is you get horrible mileage because of the fuel not burning all the way or something. there is nothing to be gained using 93 over 87 or so
i suppose if you changed your plugs (went hotter maybe?) then you could reap the benefits, but i dunno.
back on topic
Old Jul 28, 2005 | 03:55 AM
  #41
pusha2009's Avatar
back on topic
Doesn't the gas cap say Regular Unleaded Only?
Old Jul 28, 2005 | 04:10 AM
  #42
livelyjay's Avatar
Sorry Paul, but Fox is right on that one.
Did you guys start yet?
Old Jul 28, 2005 | 04:15 AM
  #43
awdjunkies's Avatar
Originally Posted by Shingen
... um... ok.
Fox
Just found this a bit amusing at 4am.. lol
Old Jul 28, 2005 | 09:49 PM
  #44
Shingen's Avatar
UPDATE!
Fox
PS- I'm drunk...
Old Jul 31, 2005 | 12:32 AM
  #45
Shingen's Avatar
Bumpity Bump guys...
Fox
PS- Paul call me! haha... what thread did you update excately?
