service engine soon light
Old Aug 5, 2005 | 11:46 AM
mitch44759's Avatar
Question service engine soon light
Hey Guys
My car is at 12866 miles and my service engine soon light came on. I checked the oil level and tightend the gas cap but it is still on. I just recently put on a magnaflow cat back and a cold air intake but that is it any ideas?
Old Aug 5, 2005 | 11:48 AM
datdjrobp's Avatar
disconnect the battery for a while, reconnect and see if it goes away. if not, autozone or some other car part shops will check your codes for free. bring the code back and we'll go from there.
Old Aug 5, 2005 | 11:49 AM
mitch44759's Avatar
Thanks I am on my way
Old Aug 5, 2005 | 12:06 PM
HobieKopek's Avatar
The light won't go off immediately even if it's the fuel cap. Definitely reset the ECU and/or get the code pulled.
mitch44759's Avatar
OK i got the code PO507 Hi revs... Last week i was changing my oil and just cleaning out the engine when i noticed the throttle looked a little loose so i tightend it up could this be why the revs are his.... MY Tac say 1000 at idle right now but it was reading higher before.
Old Aug 5, 2005 | 12:07 PM
HobieKopek's Avatar
That's why. Loosen it. Your throttle body should NOT be open even the tiniest bit at idle. All idle air is done through a valve that bypasses the TB, so having it open even a hair throws off the Idle Air Controller Put at least a little slack back into the wire.
Old Aug 5, 2005 | 12:09 PM
mitch44759's Avatar
thanks i am an idiot
Old Aug 5, 2005 | 12:10 PM
HobieKopek's Avatar
**** happens, man. I did it on my car after my rebuild too. It's very easy to accidentally make it a little too tight.
Old Aug 5, 2005 | 12:23 PM
datdjrobp's Avatar
look at me helpin' the newbies like i know what i'm talking about. LOL
Old Aug 5, 2005 | 12:25 PM
HobieKopek's Avatar
At'll do, Rob. At'll do.
