New CAI
Old Aug 11, 2005 | 07:08 AM
mojoe's Avatar
New CAI
I just installed a CAI on my 2004 Automatic Lancer (just moved the battery out of the way to fit it in there, nothing fancy) and I had a few quick questions. Number one is that when I slow to a stop the throttle drops down to about 500-600 RPMs and then jumps back up to around 1000 so is that abnormal and is that bad at all? The other question is about the wheel well covers. Should I have any of them removed? I mean do I need to have the CAI open to the outside or is it ok just left inside the front wheel well?
Old Aug 11, 2005 | 07:20 AM
gregivq's Avatar
Using the search button you would find out that it is normal for your idle to be crazy at times after installing CAI or short ram.
Next time start a thread here :https://www.evolutionm.net/forums/evom-new-member-faqs-evom-rules-61/
Old Aug 11, 2005 | 07:28 AM
blaze_125's Avatar
Your battery was probably disconnected for more than 10 minutes so your Ecu went back to it's starting point. It's got to learn again. Give it a few miles and it will go away.
Old Aug 11, 2005 | 09:15 AM
SLVROZ_03's Avatar
Yeah, the auto tranny lancers, like mine, will do that after the ecu is reset (assuming that is what you do). If not, disconnect that batt for 10 min +; then re-connect. Then it will re-learn the shifting points again.
Old Aug 11, 2005 | 05:58 PM
mojoe's Avatar
Cool thanks for the answers, sorry if I posted this in the wrong forum. Now does anyone know about the wheel well covers? Should I have one off to expose more air to the filter?
Old Aug 11, 2005 | 06:04 PM
SLVROZ_03's Avatar
Unless you live somewhere where there isn't alot of standing water left on the road after a storm, or you have a Bypass valve in-line I wouldn't.
Old Aug 11, 2005 | 07:35 PM
onebadmitz's Avatar
i took my covers off man.....i was told that they creat drag and with the removal of them it gives your cai more air...
