DOCH 4g93?
Old Sep 27, 2005 | 04:50 AM
4Gaijin63's Avatar
Originally Posted by AirQuez
...On the 4G69, the throttle cable goes right where the power steering pump and cruise control module is of the 4G9x's. I see custom fabbing still, to swap these motors in a 4G9x.
dear lord no! not the throttle cable! well good game guys the dream was fun while it lasted
Old Sep 28, 2005 | 08:04 AM
HobieKopek's Avatar
My real problem with the 4g69 swap is that there's no real benefit to it. By comparison it makes a 4g63 swap look smart. At least the 4g63 has tons of aftermarket parts and is known to be more or less bulletproof. The 4g69 makes significantly less power, has only a fraction of the aftermarket, and would probably take nearly as much time, money and effort to swap in. Why? Just why?
Old Oct 4, 2005 | 11:10 AM
KillahB's Avatar
Originally Posted by WADADLIG_OZ
Hey
Just cause you have a ralliart now don't be a dream crusher!!!!
WADAD
I'm going to crush more than dreams when you bring that slow Lancer around town ........
Just staying NA.... if it wasnt a difficlut (and pricey) swap, I would look into it as an ooption to stay NA. 165 hp with variable valve timing is a nice starting spot. You are right up there with most of the "performance" import sub-$25K cars out there now - the Civic Sis, GSRs, SE-Rs, tCs and would be ahead of most older cars, like older Hondas, and Nissans and Toyotas. I think it would be good starting poing NA, even thought of swapping it into my Mirage, but too much of a PITA plus the 'Rage's name is Turbo Madness .......
Old Oct 4, 2005 | 11:15 AM
HobieKopek's Avatar
It's obviously a lot of personal bias there, but I don't see the point in swapping the 4g69 when it would probably save you a lot of headaches just to trade up. I have nothing against the 4g69 as an engine, but the problems and expenses that swapping an engine can create make me think it'd be smarter to simply buy the Ralliart and eat the trade-in losses.
Old Oct 4, 2005 | 11:18 AM
KillahB's Avatar
That is true too, except that all my logic applies to a 2-door 2400ish lb car. I keep forgetting I am on the Lancer board and need to apply my logic to Lancers .......
You make perfect sense. Instead of swapping, it would be more feasible to just buy the RalliArt outright .
Old Oct 4, 2005 | 03:40 PM
WADADLIG_OZ's Avatar
Not everyone can run out and buy a ralliart
I'll take my lix come Weds, but eventually there WILL come a time....
WADAD
Old Oct 4, 2005 | 06:42 PM
KillahB's Avatar
WADAD
Now you got me scared and that is half the battle....
Tried some launches tonight so that I wouldnt look like an idiot tomorrow and at 3K, tyre spin, 2.5K tyre spin ... .. gotta launch at 2K tomorrow and see what happens .
Old Oct 4, 2005 | 07:05 PM
Not to scare you but the track is usually a little slicker than the street.
YOu might have to launch at 1k
I'll teach you a few tricks when we get there...
BOT
Can you imagine a 4G69 taking help from a SL-OZ lancer 4G94
WADAD
Old Oct 15, 2005 | 12:23 AM
High Voltage's Avatar
Post
Originally Posted by AznFlip
Because RA has 5 wheel studs and base lancers has 4, unless base lancer axle will fit on RA tranny, but if not, you'll have to swap them, even the rears, or it woudn't look right.
Still couldn't you convert the lug pattern in one way or another?
Old Oct 15, 2005 | 08:05 AM
KillahB's Avatar
Nope. You are 4x100, Ralliart is 5x114.5 ..... nothing you can do but change the entire hubs and everything.
RobGinSki
Lancer Engine Tech
Jun 27, 2024 11:22 AM
nestoledo
Lancer Aftermarket Forced Induction Tech
Jun 19, 2011 06:39 AM
Seifer780
Lancer Engine Tech
Sep 19, 2010 10:43 AM
SilvOzRallEdit
Lancer-Mirage Compatibility Forum
16
Jan 1, 2007 08:46 AM
954gls
Dec 23, 2003 08:36 PM
