Mechanical o2 seems to work w/ RRM header!
Old Sep 25, 2005 | 06:42 PM
N1te's Avatar
LOL Alchemist or Boe should be in this thread soon to set all of you guys straight, but since they haven'et yet, I suppose I'll have to. The only thing that the second O2 sensor does is (from what I've gained but could be wrong) is check if the first cat. is working. When you remove the first catalytic converter, the second O2 sensor picks up on it and your CEL goes on. The first O2 Sensor reads the air/fuel ratio and adjusts accordingly for the ecu and is responsible for your engine running rich/lean and properly. It's widely functional. The second O2 sensor sees if everything is or isn't okay. Which is why you will or won't get a cel. Pulling it out with the antifoulers like the evo guys did has no negative affects, as the second O2 sensor has no effect on anything major in your car. Hobie told me a while ago before he fixed his CEL that his car ran better with the CEL off, but it wouldn't have been anything major. That is why people can remove the second O2 sensor and put there wideband in the same spot if they really wish too, because the second O2 sensor serves much less purpose than the first. You get a lot more.... whatever the second o2 sensor detects coming in with the first cat removed so you must pull it out so that it reads "whatever" in the correct parameters.
Old Sep 25, 2005 | 09:57 PM
chummer-x's Avatar
yeah, that's what i did. now the car is looping while i'm in idle/at the stop light.
Old Sep 25, 2005 | 10:00 PM
EarsLikenElf's Avatar
What do you mean looping?
Old Sep 25, 2005 | 10:02 PM
lookslikeanevo's Avatar
reset the Ecu? try it
chummer-x's Avatar
it will stay at 700rpm(normal) and sink to 500rpm. back and forth? gotta clue?
Old Sep 25, 2005 | 10:03 PM
chummer-x's Avatar
reset the ecu 3 times already, same out come.
Old Sep 25, 2005 | 10:04 PM
Ahh... I know it will do that when you reset the ECU. But i didnt have that problem. After you reset the ECU, let the car idle for about 10 min, then take an easy test drive. I dont beleive the car completely learns untill around 70 miles, as that is how long it took for my CEL to come on after installing the RRM header(w/ out the cel fix)
- Andy
Old Sep 25, 2005 | 10:06 PM
Just give it some time, it will go away. If it does it after 100 miles... dunno know what to tell you, but it will do it untill the ECU learns/adjust everything.
Old Sep 25, 2005 | 10:07 PM
chummer-x's Avatar
nice, i will let it do that until then. thanx man, big help and hope this works.
Old Sep 26, 2005 | 01:40 PM
N1te's Avatar
your welcome.
BluesunsXIV
Jun 27, 2009 06:34 AM
J Nasty
Dec 13, 2006 10:41 PM
Dingo7
Mar 9, 2006 11:37 AM
Offender
Lancer Troubleshooting
14
Mar 1, 2006 03:20 PM
JuancaROD
Feb 21, 2006 01:12 PM
