header question
Old Jan 13, 2006 | 05:58 PM
abcarino's Avatar
header question
hi guys...
i have a 1.3 2004 lancer 90hp it is not bad 0-100 11.4 sec
i installed air intake system and i felt hp gain but i need much more hp so iam asking about header and how much hp it will gonna give..
and when u install a header u must have an exhaust system as i dont like exaust system especialy it`s sound , so installing header without exhaust is a benifit or not??? thanxx
Old Jan 13, 2006 | 07:38 PM
NateOZ's Avatar
He obviously has a non USDM lancer. Im sure he means 0-100 km, which is the same as 0-60mph. My advice to him would be to pop his hood and post up his engine code, maybe some members here would recognize it and be able to help him out.
EDIT: read a few of his past posts and yep he is driving a lancer from egypt. Engine code is 4g13. I have never heard of the engine, but maybe someone here has.
Old Jan 14, 2006 | 01:08 PM
KillahB's Avatar
He probably has a non-USDM lancer with the 4G13 engine in it. Contrary to popular belief on here there are overseas members with Lancers other than the 2.0L. The 4G13 is a 1.3L "beast" - 1.3L and I think about 74 hp or something insane like that.
To the original poster, that engine is a dead horse. See if you can source either the 4G18 16 valve engine or at the very least the 4G15 16valve ... make sure it is 16 valve tho because the 4G15 12 valve is also a dead horse.
Old Jan 14, 2006 | 02:56 PM
abcarino's Avatar
hi guys
i wanna tell u something...
iam from egypt and here we have 2 versions of lancer sport and non sport, the sport look slike the oz-rally and the non sport looks like you es version , beside options we have 2 versions of engines 4g18 with cvt gear which provides 122hp , and the other engine is 4g13 90hp manual...my car is 1.3 sport manual , both engines are sohs 16 valve . the 4g18 0-100 km is 10.7 sec automatic cvt & the 4g13 manual is 11.4 sec , 4g13 automatic is 13.7 sec, ofcourse km/h not mile!!!!
anyway these models are called gl and glx specifications are for middle east region..
PLZ REPLY TO MY ORIGINAL QUESTION...thanx
Old Jan 14, 2006 | 03:22 PM
Walkingchaos's Avatar
ok now that that is sorted out back to you question. Every little bit helps. Yes doing a header without exhaust will give you a gain, just not as much as if you did the full system. Seeing as you have the non-USDM motor im not sure that alot of us could be alot of help in directing you to parts for your ride. I have no idea how your engine bay is laid out or what kind of manifold studs you have. But goodluck finding stuff. Magnaflow makes some prett good exhaust systems as does greddy.
Old Jan 14, 2006 | 03:40 PM
Blacksheepdj's Avatar
Cleaned thread.
Not everyone is from the USA, geniuses... so think before you insult.
Old Jan 14, 2006 | 04:28 PM
abcarino's Avatar
but around how many hourses will i gain after the new header with the cold air intake system???
its 90hp can it reaches 100hp after these upgrades??
Old Jan 14, 2006 | 04:51 PM
hmm . .good question. Im not sure but id say on that block with the header and intake youre looking at what maybe a 5-7hp gain. Youll get close but youre gonna need a couple of other things to get you over 100hp.
Old Jan 14, 2006 | 05:06 PM
abcarino's Avatar
thanx alot man
amd what about changing the ecu??
like swapping an 4g18 1.6 liter ecu from a wrecked car and installing it on my 4g13 will it make any difference??
Old Jan 14, 2006 | 08:06 PM
BAD IDEA . . an ECU is programed for your particular engine, swapping in an ECU from a different engine is simply going to cause all sorts of wrong readings. What you can do is get ECU piggybacks like RRM makes that modify the existing signal to change the power curve.
Old Jan 15, 2006 | 05:19 AM
Mitsiman's Avatar
There is not a lot known about these little engines as such. If your engine is teh 4G15 SOHC 12v model engine then headers an other stuff will work, but a rising rate FPR unit is recomended first to eliminate inherent flat spots due to it being a MAP sensor design air adjustment system.
Most of the stuff from the 4G15 late model mirage vehicles shoudl go across to yoru vehicle -= the 4G18 engine on the other hand there is nothing made for them by anyone at this time. THey are not the same as teh 4G15 engine family they are a hybrid 4G15 / 4G9 engine setup and are just plain weird. Available in the Proton family - there may be stuff coming out soon for that model but won't be for months yet.
Old Jan 16, 2006 | 02:16 AM
Chewie4299's Avatar
If you do a header maybe you can also get ahold of a pretty quiet aftermarket muffler and have some custom piping done? it should help you get closer to your 100hp goal and you should be able to avoid the loud exhaust sound you said you would rather avoid.
OT i have a question, why is a lancer with a 1.8L engine putting out 122hp stock and our 2.0L is 120? How can this be? Why must Mitsubishi torment us? lol
Old Jan 16, 2006 | 03:38 AM
Mitsiman's Avatar
Lol - the universal questions. WHy do they do this?
Old Jan 18, 2006 | 10:43 AM
Punishment. We didn't buy enough Mirage LSs, so is punishing the ricerboys that buy Lancers now. Everytime a kid with a 97 Mirage goes "yeah, my car is actually just as fast as yours" and we cry, wins.
Old Jan 18, 2006 | 12:15 PM
HobieKopek's Avatar
Because HP is a strange and arbitrary tool for measuring engine output. Our car makes the power earlier in the powerband and provides more torque (130lbs/ft stock) I'm sure.
