Magnaflow 3 chamber muffler
Old May 7, 2006 | 01:42 PM
neusch11's Avatar
ok i am gonna sound like a huge noob...and thats partially casu ei am but what is this rrm you guys talk about. Sorry to ask and feel freee to flame if you need to..lol thanks
Old May 7, 2006 | 04:29 PM
TEJ's Avatar
TEJ
Road Race Motorsports
www.roadracemotorsports.com
Old May 7, 2006 | 08:26 PM
neusch11's Avatar
Sweet thanks!
Old May 11, 2006 | 09:34 AM
krimson_binome's Avatar
Yes I put a muffler in place of the resonator. It is a magnaflow straight through muffler. The only real difference between a straight through muffler and a straight through resonator is the body size. With a bigger body there is more sound absorbtion material and more material = less exhaust noise. I did a dyno run before I put it on and ran at an even 11.0 AFR. Then put on the muffler did some tuning and ran at 13.0 - 12.6 AFR. I gained 2 ft/lb torque and 1 hp. I don't know if I would have gained more if I didn't have the muffler in place of the resonator, but I'm willing to accept a couple percent loss if it means I can hear the radio when traveling at highway speeds. BTW the only reason I put in that last part is because I might have added some flow disruption because the core on the muffler was 2.5" since it was a universal slip fit that had 2.25" inlet and outlet. (velocity loss from a change in volume can cause back pressure). I recommend making the change to anyone who is not too concerned with ground clearance, but wants a quieter car with the same performance (or nearly at any rate). A 5x8 muffler doesn't fit into that channel near as well as a 4" round does, though if you d it right you really only loose about .5" of ground clearance.
Old May 11, 2006 | 09:50 AM
Danno's Avatar
Blaze you've been complaining about that exhaust I sold you for far too long. I told you when you bought it that your headers and DP made it sound much louder on your car.
LOL
I dont think you have to go as far as a 3 chamber, maybe just a second resignator and a high flow car rather then the test pipe.
bryann76yang
Feb 9, 2008 12:39 PM
kapolani
Jul 17, 2005 10:29 AM
Evofurry
May 23, 2005 06:35 AM
evoWALO
May 18, 2004 05:31 AM
