Need Help Yet Again
Old Mar 18, 2006 | 11:18 PM
DjDoubt's Avatar
Need Help Yet Again
Hey Guys,
I got the CEL Elim. From RRM. Seemed simple to so. I struggled for six hours. How the hell do I get the damn o2 sensor off the Cat? I even used liquid wrench. Any Tips?
Old Mar 18, 2006 | 11:28 PM
JerseyLancer02's Avatar
Originally Posted by DjDoubt
Hey Guys,
When I changed my cat to RRM's highflow cat...I had to use a torch to get my O2 sensor off. Came off with ease after I heated it up a bit.
Old Mar 19, 2006 | 06:39 AM
Johns Slow ES's Avatar
be careful to hot and ul mess up the threaded section of the sensor
Old Mar 19, 2006 | 08:54 AM
comatose721's Avatar
liquid wrench or any other penetrating oil w/lubricant. let it sit for a day. go back out tomorrow and spray more on..take it off in 20 minutes....or remove the whole cat out and put it on the bench....it's easier to work on it that way.
Old Mar 19, 2006 | 02:19 PM
SLVROZ_03's Avatar
Try going out for a drive...And when you return home, remove it then... Make sure to wear work gloves though!
Old Mar 19, 2006 | 05:24 PM
lancerman360's Avatar
When I got the RRM test pipe i had to remove the cat and then cut the sensor wires. then me and one of my friends had to strugle to get it off. good luck with it, it on there tight.
Old Mar 19, 2006 | 08:58 PM
no offense, what the f*ck were you thinking when you cut the wires? there is a quick-connect plug
Old Mar 19, 2006 | 09:26 PM
HobieKopek's Avatar
Right tighty. Lefty loosey.
Old Mar 20, 2006 | 11:00 AM
Yeah comatose I didnt see it. It was no problem though, only 2 wires and is not like it was that hard to reconnect.
Old Mar 20, 2006 | 11:08 AM
Handmemyarms's Avatar
oh my god...... i cant believe this is struggling issue
step 1: go to autozone pepboys ect.
step 2: put a 15 dollar deposit down on an O2 sensor socket
step 3: use socket
step 4: return socket and get 15 bucks back
Old Mar 20, 2006 | 11:12 AM
iamdedbob's Avatar
Handmemyarms FTW!
Old Mar 20, 2006 | 04:48 PM
Originally Posted by iamdedbob
Handmemyarms FTW!
Old Mar 20, 2006 | 08:46 PM
i hope you soldered them and made sure to cover it up pretty good. otherwise it could be bad news
Originally Posted by Handmemyarms
FTW --> For The Win
Old Mar 20, 2006 | 09:15 PM
Originally Posted by comatose721
FTW --> For The Win
thanks haha
Old Mar 20, 2006 | 09:17 PM
Dont worry I did. I may be a newbie to this site but I am not new at electronics and wiring things and crap.
